fluorescent (28th April, 2018)
That's why ironically said that. As I read in many forums, atmega162 has no fuses to disable those. So the worst this you can do is set it up to use and external clock. Providing a clock is sufficient to recover the chip, no need to have high voltage programmer
Enviado desde mi iPhone utilizando Tapatalk
Hello again, i finally opened my cable, in has atmega 162, and ftdi 232rl. Any advices how to make it fully working again?
xxxxxxxxxxxxxxxx
Try this.
http://obd2-diag.blogspot.com/2017/0...er-manual.html
During programming, do not forget to connect the interface to the car and laptop and run the vcds windows that you will use. (17.8.1, 18.2.0) or other.
Hello mates, I buyed a new vcds cable version 17.1 but when the item arrives the cd inside the package is damaged, I talked with the dealer and they send me a link to download the software, till there everything it’s ok but when I installed the soft I can’t find how to change the language to Spanish.
Can you provide me a version multilenguage or Spanish compatible with my vcds 17.1 ?
Thanks in advance
Jose
joze
Hi.
What cable version and where did you buy it? You should buy the English (18.2.0) and Spanish (17.8.1) versions. For example, here:
https://www.aliexpress.com/wholesale...t=vcds+spanish
(only with ATMEGA 162 inside)
or
http://www.obd2cartool.com/atmega-va...t-skoda-p-1492
(spanish est)
https://yadi.sk/d/kwoAv_pu3LkTV8/VCD...-Installer.exe
If you only bought English then ask the seller if the cable will work with the Spanish version. If it works, let it send you a link to the software and loader. Also, read the topic about updating the cable to the latest version.
http://www.digital-kaos.co.uk/forums...light=vcds+vag
joze (18th September, 2018)
Hi there. If program doesn't want open than you have something wrong with Windows... vcds software/program should Run/open without connection vcds to USB.
Or
If you copy loader to installed vcds catalogue, try loader or all this catalogue in you antywirus added to trust. Some antywirus recognize loader like virus so try this as well.
My post helps you? Please Hit Buttons
Hello
I am trying to download but i always get login error even i am logged in
I have installed vcds 17.1.0 and run fine but in English
, sometimes I see a label where say “ I must use a license software”
Let me know if you need photos from inside of interface to know what components has it got.
Today I see in the main windows when I click on vcds 17.1.3 est a windows where show “ ok “ but after that nothing happens
Best regards
jozeTo update the cable or change the language first you need to check if you have an Atmega 162 chip inside (pictures in post 363). If so you can download the Kolimer V 6.3 activator and try to convert the cable via a usb or programmer.
Post. 5823
Hello, can somebody upload vcds 18.2.0 english dump? thanks!
At mine with 18.2.0 vcds work, but not ok.
Also i tryed on the table with ecu siemens pcr 2.1 and in long codding missing all info .
i rey with 16.8.1 and all info in long codding appear- where is the problem?
what loader need to use?
Thank you in advance
turbocip
Hi. I had the same problem in version 17.8.0 PL. So I used the older version 16.8.3 and 17.1.3PL. After entering newer versions 17.8.1 and 18.2.1PL, everything is fine. Long coding works normally. The colimer did the next V7.0 activator. So maybe try updating the cable. Of course, if you have ATMEGA 162.
https://openload.co/f/XK3TyMQp9zo/VCDSLoader_v7.0.zip
Read this thread.
turbocip (10th October, 2018)
