Page 2 of 30 FirstFirst 123456712 ... LastLast
Results 16 to 30 of 441
  1. #16
    DK Veteran kelekele's Avatar
    Sonta,Serbia
    Quote Originally Posted by bursuc View Post
    still no LED's , i write the dumps, thee eeprom snd the flash on atmega, but still the LEDS are not powering up ... 7805 is working....any other ideas?
    How you connect upa to atmega 162?I have upa but i'm not sure is flashed properly or not.
  2. #17
    Oct 2008
    On Earth
    Hi mate
    As other guys told you your Atmega it is blocked
    You need to unblock it with a High Voltage Paralel Programmer or how it is named "Atmega Doctor"
    Or if your tool was burned by an K-line 12V short maybe the Atemga it is burned.
    But I supposed that it is just blocked.
    Good luck
  3. #18
    matekhr's Avatar
    Croatia
    Quote Originally Posted by mattydr67 View Post
    Hi mate
    Good luck
    Yes, right. Check SPIEN fuse bit. Must be "False" for UPA. If it is "True", only a High Voltage Programmer can help you (or a new Atmega).
  4. #19
    Top Poster + doaa's Avatar
    Mohammédia
    THANKS FOR YOU WORKING GOOD
  5. The Following User Says Thank You to doaa For This Useful Post:
    Col19 (3rd March, 2021)
  6. #20
    Jun 2012
    Thank you very very much, my cable working again!!
  7. #21
    Jun 2012
    hello,
    is possible to repair cable 11.11 to 11.11.3 ?
  8. #22
    Oct 2008
    On Earth
    Quote Originally Posted by cbienmoi2005 View Post
    hello,
    If you wanna think that if you flash the VCDS with 11.11.0 dump, this will not work with 11.11.3
    For the VCDS 11.11.3 you need a moded softwear or 11.11.3 dump
    Good luck
  9. #23
    serial for 11.11.3?
  10. #24
    Oct 2008
    On Earth
    Quote Originally Posted by marinescuv View Post
    serial for 11.11.3?
    Yes you need 11.11.3 dump
    As my friend Aminebot said in the past the dump you need to be extracted from an old interace with BM because if you have a dump extracted from a new VCDS tool you'll not be able to use it if you do not moded the softwear because it you'll ask for the FTDI RQ ID.
    Think about this and you now this dump can be for free maybe after an year at least or never
    Good luck
  11. #25
    hi , i'm new to this , but does the china blue cable work also on VCDS ?
  12. #26
    Oct 2008
    On Earth
    Quote Originally Posted by pacorabane230 View Post
    If you talking abot Vag 409 KKL blue one the answear it cannot work with new VCDS softwears.
    Just with VCDS Lite which is made for KKL tools
    Good luck
  13. #27
    tnx for 908
  14. #28
    Top Poster Africa's Avatar
    Default vcds 11.2 repair eprom 93c56
    my interface stopped working, the computer does not recognize it interface.
    Read EEPROM successful Device 0
    0000 : 55 46 55 46 55 46 55 46 55 46 55 46 55 46 55 46 FU FU FU FU FU FU FU FU
    0010 : 55 46 55 46 55 46 55 46 55 46 55 46 55 46 55 46 FU FU FU FU FU FU FU FU
    0020 : 55 46 55 46 55 46 55 46 55 46 55 46 55 46 55 46 FU FU FU FU FU FU FU FU
    0030 : 55 46 55 46 55 46 55 46 55 46 55 46 55 46 55 46 FU FU FU FU FU FU FU FU
    0040 : 55 46 55 46 55 46 55 46 55 46 55 46 55 46 55 46 FU FU FU FU FU FU FU FU
    0050 : 55 46 55 46 55 46 55 46 55 46 55 46 55 46 55 46 FU FU FU FU FU FU FU FU
    0060 : 55 46 55 46 55 46 55 46 55 46 55 46 55 46 55 46 FU FU FU FU FU FU FU FU
    0070 : 55 46 55 46 55 46 55 46 55 46 55 46 55 46 55 46 FU FU FU FU FU FU FU FU
    What could be the reason? ...
    E2prom enough to program?
    I need to program the 93C56.
    Any help?
    thanks.
    Original BDM EVC with adapters, SPI EVC, Galep5 programmer, emp11 programmer, upa1.3, kwp2000plus, MPPS, Ktag, Kess, Galletto ofiicial, and many more...
  15. The Following User Says Thank You to Africa For This Useful Post:
    Col19 (13th November, 2019)
  16. #29
    DK Veteran Artilect's Avatar
    EU
    No need to take the eeprom out. Just reflash with M-Prog3.0 or FT Prog.
    If the device is not recognized there is on DK Popsted some tools to repair VID PID of FTDI chip.
    If you will not solve. Contact me on PM tonight, im not at home at the moment.
    BR
    __________________
    If You Like My Post
    Please use the button on the LEFT side and the button on the RIGHT side.
    Tuning, EGR, DPF, AdBlue, DTC, TVA, Speed Limit, Immo...
  17. #30
    Quote Originally Posted by Artilect View Post
    BR
    I read with mprog3.5 but rarely observed reading.
    for that reason Unsolder the eprom and read with upa.
    I need internal e2p for repair the interface.
