Page 12 of 30 FirstFirst ... 2789101112131415161722 ... LastLast
Results 166 to 180 of 441
  1. #166
    Apr 2016
    what do i need to reprogram this... it says vag12.12 on the outside case. thanks20160427_174251.jpg
  2. #167
    Apr 2016
    I have an issue with one vcds 12.12.0 interface. After a low batery voltage on a car, my interface does not respond. On VCDS test it say "Interface not found error -99". This hapend a year ago, and it was fixed by the seller of interface for free (warranty). This happend again, last week. When I connect to USB, an over current error ocured. I open it, and the FT232RL chip was hot,(hot enough to remove itself from pcb). I orderd a new FT232RL chip, solderd in place, progrmmed with mprog. When I tested on VCDS now, it say "Interface found and not conected to car". When I connect it to car, the led stay red for 1 sec and after become green. If I test it now, it say "Interface not found".Try to open a connection with car (ECU) and appears error -2 no communication.
    Any ideea how to fix my VCDS 12.12.0 interface?
  3. #168
    May 2016
    Default VAG11.11 Dual-K & CAN FT232 BL & Atmega162
    OK I have a Dual-K & CAN Vag11.11 too with the same connection problem. It get's disconnected every 5 seconds. I've used lots of dumps from this forum but no one works fine for me. I uploaded some pics with it.
  4. #169
    May 2016
    still no LED's , i write the dumps, thee eeprom snd the flash on atmega, but still the LEDS are not powering up 7805 is working any other ideas?
  5. #170
    May 2016
    @umitasa I'm pretty sure your Atmega162 is clean or the dumps used are not the good ones. If your vcds worked before you have to try other dumps. What type of programmer did you used to flash the chip? What soft?
    P.S: In time you write the dump on Atmega chip the led is blinking red?
  6. #171
    gopelhu's Avatar
    EU
    Hi all,
    some peaple asked me this VCDS 15.7.x atmega dumps.
    I created a solutions this version, here is....
    ENJOY all....
    I need to know working or not? If you have an installed version the you need to save a d1,d2,d3 bins
    After install the v15.7.x version and copy the files and plug the interface with this dump and run the sw and check the about page.
    Regards, G
  7. The Following 18 Users Say Thank You to gopelhu For This Useful Post:
    amaflo (7th June, 2016), Anmed (1st August, 2016), ARNAU (9th June, 2016), azza2 (2nd August, 2016), brodaty (29th July, 2016), Col19 (13th November, 2019), ecufix (21st May, 2016), hp7909 (19th June, 2016), mehdi24 (17th December, 2016), paro44 (20th May, 2016), seba2711 (25th November, 2016), sonique (23rd May, 2016), vanos batam (20th May, 2016), viorelcarl (20th May, 2016), vpetre (22nd June, 2016), yaca (6th June, 2016), zeljolaki (26th September, 2016)
  8. #172
    Feb 2013
    As I see, it is only for RL?
  9. #173
    gopelhu's Avatar
    EU
    Quote Originally Posted by alexm1 View Post
    yes, it's ft232rl
  10. #174
    Quote Originally Posted by gopelhu View Post
    Hi all,
    ENJOY all....
    Regards, G
    Gopelhu which V15.7.x version do you use? oem one? or where can I find it?
  11. #175
    marek128's Avatar
    Jun 2012
    dont work. when plug dongle to supply interface not connected. without supply car not connected.
    I tried china 11.11.3 unit
    If I help You. please say THANKS.
  12. The Following User Says Thank You to marek128 For This Useful Post:
    gopelhu (22nd May, 2016)
  13. #176
    gopelhu's Avatar
    EU
    Quote Originally Posted by marek128 View Post
    Ok, thanks for the info. I will create the d1,d2,d3 files and i will upload.
    I see the interface found and the type of interface, its ok.
    Later ......
    Regards, G
  14. #177
    fantomel's Avatar
    Mar 2009
    Us
    you can create 100 d1-d3 files because are useless. those files are just initial check , so smoke in the eyes of the user. That is all.
    A good dump does not need d1-d3, it makes them on 1st test of interface and if is ok or not you see the sn green or not.
    If you like my post and it helped you please press THANKS.
  15. The Following 3 Users Say Thank You to fantomel For This Useful Post:
    electronistul21 (23rd May, 2016), gopelhu (22nd May, 2016), paro44 (23rd May, 2016)
  16. #178
    May 2016
    Gopelhu, thanks for vcds 12.12 dumps (from post). Now I alredy restore my china 12.12 cable with these dumps.
    Cable have Atmega and ft232rl only (no GAL or ATF). So, I use provided SW (VCDS-Release-12.12.0-Installer English 512bits.exe) and flash atmega witch fw and eeprom.
    No changes required for ft232. Atmega lock fuses leaved unprogrammed (disabled all locks).
    I divide FW+EEPROM dump to separate files and convert its to Intel HEX, because I use AVERDUDE for flashing.
    https://mega.nz/#!FB4xjbgA!51wHL0J_M...jrzUPraXk-Kado
  17. The Following 6 Users Say Thank You to kiyrik For This Useful Post:
    Col19 (13th November, 2019), gopelhu (22nd May, 2016), jmac200t (16th February, 2017), Menber (25th February, 2017), RogerioAndrade (10th March, 2017), seba2711 (25th November, 2016)
  18. #179
    gopelhu's Avatar
    EU
    I like that everyone is asking for help.
    When I help everybody, then they are criticizing.
    Now I stop my VCDS assistance.
    Then when I get a request for help is what I wrote last time, resolving all my limitations.
    Good luck for everyone !!!!
  19. The Following User Says Thank You to gopelhu For This Useful Post:
    SchrodingersCat (4th June, 2016)
  20. #180
    marek128's Avatar
    Jun 2012
    U doing great job mate, pls dont stop. 100 users like ur work 1 not. dont give UP bro.
    NOTE:
    In mcu eeprom is serial number with come sync to GAL/ATF they need to be from same unit not corrupted. Software PC check this. if not pass - unauthorized...
    P.S. 12.12.0 CODING dont working.
  21. The Following 6 Users Say Thank You to marek128 For This Useful Post:
    Col19 (3rd March, 2021), gopelhu (23rd May, 2016), kiyrik (4th June, 2016), Menber (25th February, 2017), proginfo (2nd June, 2016), SchrodingersCat (4th June, 2016)
