paro44 (8th February, 2016)
Just want to post a "Hello" and thank you, I'm new to the site and finding it very usefull! Thank you all
Hallo,I need tutorials to make VCDS interface from Chinese clone ELM 327 USB v1.5a.Could some people help me please with it...was trying to download that VCDS all rar.file, but got a mistake.Thx.
Last edited by olegdon; 15th February, 2016 at 12:54 PM. Reason: To add information
Its imposible mate
To diffrent kind if tools
ElM327 is using PIC MCU and VCDs is using Atmega MCU
This is just first major diffret.
Actually ELM327 is 100% diffrent then a VCDS Hex-Can
Good luck
olegdon (28th February, 2016)
Now, i have no answer of my atmega. I will change an reload it.
Can you tell me the best way and the best dump to use?
You flashed wrong fuse bits
If you bootloader is 256 words you can set the fuse its as below
CD DC F9 FF(CC)
If you bootloader is 512 words you can set fuse bits as below
CD DA F9 FF(CC)
Good luck
paro44 (23rd February, 2016)
Col19 (13th November, 2019), nelumuresan (31st October, 2016), tyrystor (10th July, 2021)
I test this dump this morning, i have the message "Not connected to car".
Maybe I don't use the good fuse bit
CD DA F9 FF
Power the tool
And set the fuse bits CD DC F9 CC
Because it the fiwmare with b256 words
Don't forget to set the fusebit not only write it
When test the tool plug ut into the ca or power the 12v
Good luck
I update with those parameters CD DC F9 CC FFFFFF60if I power the cable per the ODB connector the led is blinking I thinks it's seem to be goodBut the vcds 11.11.3 still say interface not connected. I force a reinstall of the driver with same result. My id is 403 & FA24I test with my version 12.12.1 and the software see the cable and ask for an update to 1.92. Maybe I have to test with a dump of 1.92. Normally my original dump is 1.93 but do I have to use the same fuse?Thanks
Led blinking red this is not good
You did there a miskake before start flashing the tool
The 1.92 or 1.93 we cannot call it dump.
The Atmega dump means bootliader + firmware + eeprom
1.92 or 1.93 is firmware
Bootloader + firmware = flash
Eeprom is the serial
To flash an Atmega in VcDs you need flash+eeprom+fusebits
So take care what are you doing there
Do you have good eeproms for the vcds versions that you wanna use?
Think
Good luck
