Page 16 of 30 FirstFirst ... 6111213141516171819202126 ... LastLast
Results 226 to 240 of 442
  1. #226
    Oct 2008
    On Earth
    There are two type of HQ clones
    Both upgradable
    1. One use cracked softwares and need to wait the seller to provide new software to be able to update
    2. The other is using official softwares no cracked. In this case when a new software is released you can upgrade your tool
    I have the second choise one that can be upgraded with officiale not cracked softwares when this one are released
    I will not share any informations where you can purchase one of this HQ clones. Sorry!
    Good luck
  2. #227
    Sep 2016
    I have dump 15.7
  3. #228
    Sep 2016
    I have a clone of VCDS made in Belarus and it is bricked after my friend tried to check his car. Originaly it was like vcds 12.12 with firmware v1.84. This cable is based on Atmega16. So can I flash it with vcds dump?
  4. #229
    Feb 2013
    Share some pictures to see what is under de plastic cover?
  5. #230
    Oct 2016
    I have this serial adapter : http://www.delock.de/produkte/G_61425/merkmale.html and my question is:
    Can i make this serial adapter to work with any version of VCDS?
    I need to make cable only for my car: VW Golf 5 2007
    Thanks in advance
  6. #231
    Feb 2013
    Of course not
  7. #232
    Oct 2016
    dear matty, I have a chinese VAG 10.6.4 and locked because un-mod software used. I've used the 1.92 flash, 232rl.ept and eeprom in 'VAG-COM MULTI STUFF.zip' and flashed them successfully. After I plug the cable in car, I got 'K2 short to ground' message, but the cable was functional. I've tried full auto-scan and clear error code, it worked fine.
    So is the 'K2 message' a normal message when upgrade an old cable to new firmware?
    My cable pictures are below.
  8. #233
    What version of VCDS used?
  9. #234
    morfej's Avatar
    rocdeng ... it's not normal that you have K2 message. You are just lucky that K2 is not used so much on newer cars.
    Might be GAL(ATF) that is not totally correct or one of the transistors used for K2.
    br
  10. #235
    Oct 2016
    Both 11.11.5 and 12.12.0 all the same message.
  11. #236
    Oct 2016
    Maybe I broke some parts in reparing by mistake, and fortunately normal operations could be used
    Somebody also told me maybe some transistors are broken.
  12. #237
    Feb 2013
    Check first image to identify continuity path between obd2 pins and selected area in the second picture. You will find the bad T. Be carefully when solder out/in a new one...you could damage your pcb.
  13. #238
    Oct 2016
    In the morning I found the first image on Ross-tech's website and identified the path of K2, and found it's totally disconnected... Maybe Chinese clone save it for cost. But I'm confused why it's all right when I was using the old firmware 1.84 + 10.6.4 ZHS software, maybe the firmware and software were all modified?
  14. #239
    Feb 2013
    In the end, it is a clone...and things like this could happen...
    P.s.
    I have same hardware as you and using 14.10.0 on it, no troublles at all...try reflash and see whats new.
  15. #240
    Hi!
    Does anyone have dump for vcds 10.6.0 (eeprom 93c46)?
    Thanks in advance!!!
