VAG-COM/VCDS LATEST DUMPS - Page 24
Page 24 of 30 FirstFirst ... 141920212223242526272829 ... LastLast
Results 346 to 360 of 441
  1. #346
    Dec 2017
    Dears,
    Please can i have the dumps for VAG 12.10
    i think it blocked after connected my lap to wifi while cable connected, now it always says "not plugged into car" while it's connected and led up with green color.
    Many thanks for your support.
  2. #347
    Dec 2017
    Quote Originally Posted by jokeriphone View Post
    Hi Boys ! This is all what you need to work with VCDS_17.8.0 and Clone unit
    Frimware and Software + Instructions
    Pass pm and only for real members DK
    can this be flashed to 11.11 atmega FTDi?
  3. #348
    Oct 2017
    Timisoara
    hello. i have a 409.1 kkl cable. he is recognised as usb to serial converter but in vag 409 / 311 i test the interface and say com port found, interface status 3 : not found or not ready. the chip inside is ft232BL . i need a dump to reflash or what is the problem?
  4. #349
    xoom's Avatar
    Dec 2009
    Ylakiai
    there is nothing to reflash.. just check what com port it creates in device manager.. set from 1 to 4 and set same in vagcom409.. and you good to go its just K line adapter..
  5. #350
    Oct 2017
    Timisoara
    i know. he didint work. i have another 409 kkl cable and that is with ft232rl chip and that i reflashed with a dump file in mprog and he worked ok. tihis is with ft232bl and don`t work
  6. #351
    Feb 2013
    This is not about FTDI...It is about main cip, we talk about dump for Atmega.
  7. #352
    Dec 2014
    PL
    Quote Originally Posted by ramyhossni View Post
    Dears,
    Hi.
    You have an Atmega 162 chip so you can program it. Here you have a link how to do it. In addition, the topic for further
    updates
    http://obd2-diag.blogspot.com/2017/0...er-manual.html
    http://www.digital-kaos.co.uk/forums...light=vag+vcds
  8. #353
    Oct 2013
    Czech republic
    Hello Jokeriphone,
    pass please .
  9. #354
    Dec 2014
    PL
    [QUOTE=HLAVICKA11;3224812]Hello Jokeriphone,
    pass please .
    Thanks[/QUOTe
    Try this.
    https://cloud.mail.ru/public/4xNX/2u9c8ZfP3
  10. #355
    Jan 2016
    Romania
    can update from 11.8 to 11.11?
  11. #356
    Dec 2014
    PL
    Quote Originally Posted by divinul View Post
    Read post 352 and links.
  12. #357
    Mar 2018
    Quote Originally Posted by Mario6 View Post
    Hi. Has anybody Broken te fuses like me ? I seems that ponyprog messed Up mines and I am no longer able to contact my avr
    Enviado desde mi iPhone utilizando Tapatalk
  13. #358
    Feb 2013
    It is possible that you ve bloked Atmega from reading...it is a device to unblock but will cost you more than 100$...easy way buy another cable or replace atmega...
  14. #359
    xoom's Avatar
    Dec 2009
    Ylakiai
    depends on what fuses you changed.. maybe disabled ISP.. or maybe disabled RESET.. there is HV parallel programmers but cheaper is another atmega
  15. #360
    Mar 2018
    Quote Originally Posted by xoom View Post
    Recovered !! This chip model the worst you can do is set to use an external clock source. So using a raspberry pi3 set a gpio pin to output a 1mhz clock freq into atmega's xtal1 pin and voila !! Used an lpt1 port to contact built-in ISP
    Thanks all
