I buy the xprog-m clone, just one read, was all new, and sey Update firmware?... and now a nice metal box
china clone ?
hello Holtek
pls check this thread.. http://www.digital-kaos.co.uk/forums...eeprom-292723/
maybe you can solved?
thankyou
Maybe somebody has Xprog-M PCB in PDF or any other format? Please share
Thanks in advance
vanos batam - I downloaded your ATmega64 dump. On my hard drive I have many dumps, different versions of the XPROG. I compared Your dump, and I'msure that this is not a dump for XPROG-BOX 5.4.3. This is not a dump for any version of XPROG-BOX.
It is the XPROG-m 4.5 dump!
If you set fuse follow my manual, this dump works correctly with XPROG-m version 4.5 and after updating the firmware works correctly with XPROG-m version 5.0.
Has anyone used the files to make a pcb or has a file of the pcb thats ready to be printed??
upload 5.3.5 soft
Ok I loaded cfg.bin and EEPROM.bin, when I first 'read' atmel it gave me that my original configuration was FF FF CA 2F
Now when I try to write, it changed config file to FC FF CA 2F, but it wrote a totally different EEPROM file than the one I loaded ....
I erased EEPROM and wrote again same EEPROM file, and when I read EEPROM it still gives weird eeprom file.
Eeprom file attached.
Last edited by demos70; 27th November, 2012 at 01:32 PM. Reason: Trying to upload file
hi all am looking at these programmer for my own use now theres a lot of intresting stuff on here about these devices i ve just purchased a upa programmer and going to do some experiment with peugeot bsi s so may need some help from you guys in the near future kep up the good work and this fourum is the best one for help and knowledge
best reguards to you all jason
instakeys (11th April, 2014)
good solution with x-prog m 5.3 to 5.0
Many people ask me how to program the ATMEGA64 in XPROG with UPA-USB. Below is a picture that will explain everything.
Finally, I publish the final version of XPROG schematic diagram rev. B. Fixed some bugs and added marking elements, as well as on the original PCB to XPROG-BOX from ELDB.
andrius (24th September, 2013), aussiediag (7th May, 2020), AYD (4th February, 2017), Bogov (4th May, 2017), boxsport (27th September, 2019), Brolk (30th July, 2016), BU508D (6th October, 2017), cjawahir (21st May, 2016), cocutanu (22nd September, 2013), giani03 (25th June, 2014), kaalis (4th September, 2022), kalico (5th November, 2014), lucianosantos (26th January, 2014), maremuruk (16th March, 2017), Msmax (15th September, 2018), otojm (23rd May, 2016), shetaabco (15th November, 2013), srscrash (2nd October, 2013), stanislav georgiev (23rd March, 2019), stefaudio (23rd September, 2013), t1tan1 (11th April, 2014), tamer1024 (13th October, 2018), tehnosoftex (28th September, 2013), zalimhan74 (10th December, 2017), zdzicho1233 (13th April, 2014), Zmann (23rd September, 2013)
" access violation at address 00405394 in module XprogDesktop.exe . read of address 000003FC " this message keep getting when I go to read a file. There is a solution;
ok ok change pour
I have chine clone and when I try to read 9s12 or 1d69j, first time when I read receive "Verify error", but when I click second time the button "Read", then I read correctly the mcu. How I can fix this problem? When I reading FLASH of 9s12 and then I recieve "Verify error" can I damage the flash?
Thank you
daxxer (31st May, 2014), stanislav georgiev (23rd March, 2019)
