ET9000HD Discussion
Results 1 to 9 of 9
    aftermath's Avatar
    Mar 2008
    Default ET9000HD Discussion
    Please Post any Clarke Tech ET9000 Discussions in Here.
    Aug 2011
    Newcastle
    Default Problems with ViX skin on 2.2.1
    Has anyone had any performance problems using the ViX skin on version 2.2.1 of the ViX image? For a couple of months I noticed bad slowdown where the receiver would not respond for up to 10 seconds at a time. I changed the skin to use Magic HD and since then have not had any problems at all. Hope this is helpful for someone
    Sep 2010
    i have never heard of a single person having slowdown issues using the ViX skin, have you got picons or a EPG set up and if yes how are they set up and where do they save to ? for example internal flash or a USB stick ?.
    Aug 2011
    Newcastle
    It is very strange I agree, but indeed that is what happened on my setup. I do have both the EPG and Picons setup saved to a USB stick. Using CrossEPG it retrieves data for approx 5 different satellites including 28.2e
    Sep 2010
    Quote Originally Posted by Im85288 View Post
    thats the problem, your asking way too much of crossepg in a single go.
    Aug 2011
    Newcastle
    Thanks for the tip, I'll try to reduce the number of feeds crossepg accesses and see if that makes a difference when using the vix skin.
    Sep 2010
    it has nothing at all to do with the skin it's just crossepg can be a little hungry when using too many sources.
    Apr 2011
    someone tell which images best for ET9000HD
    Member afc007's Avatar
    Mar 2010
    Quote Originally Posted by Gokhle View Post
    there are plenty to choose from and now most images are very much the same in what they offer or can do
    however i would recommend either an open pli or any of the many oe2 Alliance available.
    xtrend ET 9000 HD , ipbox 9000 HD & 1mtr Dish
