Mitchell OnDemand 5.8.2.35 3Q2011 (25.11.11) ENG - Page 4
Page 4 of 4 FirstFirst 1234
Results 46 to 59 of 59
  1. #46
    Member zorba anton's Avatar
    Buffalo NY USA
    Default MOD Volkswagen Repair Manuals
    This program consists of 3 CD's. The disc content is as follows:
    Disc 1: This CD-Rom Contains All Models From 1983 - 2000 / Disk 1 - Run Setup
    Disc 2: Data Disc - Disk 2 - No Installation Required - Important Information Required For Some Models
    Disc 3: Golf / Jetta / GTI 1999 - 2005 - This CD-Rom May Require Adobe Acrobat Reader
    Installation: Please read NFO file carefully.
    -Burn ALL 3 .iso discs using ImgBurn (I couldn't make it load using anything else).
    -Install from newly burned CD 1 - (Code is 1234)
    -Read & agree to terms, Click O.K. where needed and add information as needed.
    -Allow Program to register (not to worry, it registers the CD on your system, No where else)
    -Discs 2 & 3 are Stand Alone data discs. (Need to be inserted for certain models)
    WORKING ON NEW LINKS
    Last edited by zorba anton; 3rd August, 2012 at 05:08 PM. Reason: Removed Dead Links
  2. #47
    Buffalo NY USA
    Default Mitchell On Demand Vintage Auto Manuals 1960 - 1982
    | ebook collection | 1.93 GB
    Wiring Diagrams
    Domestic Auto & Truck - 1960-1982 - 237M
    Import Auto & Truck - 1962-1982 - 155M
    Engine Mechanical, Chassis & Electrical
    Domestic Auto - 1965-1982 - 638M
    Domestic Truck - 1965-1982 - 473M
    Import Auto & Truck - 1965-1977 - 562M
    Removed Dead Links
    Last edited by zorba anton; 28th March, 2013 at 05:09 AM. Reason: Removed Dead Links
  3. #48
    Buffalo NY USA
    NO this hola es en espa?ol este programa, it is English
  4. #49
    Feb 2011
    Someone got his hands on the 2012 version?
  5. #50
    Mar 2010
    California USA
    Is the 2011 version staying up and running?
  6. #51
    Buffalo NY USA
    Quote Originally Posted by integlikewhoa View Post
    It's Posted! All Links Are Working!
  7. #52
    Im using the Mitchell 5.8.2.35 data with the previous mitchell installation version. So whats the difference with the install files version 5.8.2.35? Anyone have the 2012 version posted?
  8. #53
    May 2010
    Quote Originally Posted by The Strokes View Post
    Previous installer uses the floppy activation, newer version uses a key activation, so you'll need the crack provided to work, nothing different in the GUI just activation method. my advice is to use the 5.8.1 installer with the newer data if you can, I do, and it's working good...
  9. #54
    Feb 2011
    Quote Originally Posted by zorba anton View Post
    Link for part 14 is not working :/
  10. #55
    Mar 2010
    Quote Originally Posted by aymanmomani View Post
    I have downloaded this and then solved the math problem but it gives me an error in the picture
    Any solution ?
    I had the same thing on one of laptops, Dell. Problem has been fixed by updating BIOS. But I still have license error after shutting down computer/ restart Mitchell. Even without Internet. Any help?
  11. #56
    Mar 2010
    Quote Originally Posted by cyph8r1975 View Post
    Could you please share info How to use 5.8.1.9 with data from 5.8.2 on Windows 7?
  12. #57
    Dec 2021
    thanks bro
  13. #58
    Jul 2023
    links are dead, any one has the data only? already have the software installed but no data. please help. thanks.
  14. #59
    Oct 2023
    can u send the mitchell ondemand file i can download it please thank you
