Well yes but you wil have to change the elevation slightly and lnb skew ever so slightly to get the best signal... The satellites are in a arc... Thor being highest here in the uk..
How big is your dish?
Read the Rules here; they apply to EveryOne.
__________________________________________________
DM800s HDOpenbox S10
TM500
DM500s
90cm FortecStar dish
Technomate 2300 motor powered by UsalS
my dish is 90cm do i edge up slighlitly to get more channels
Well if you want a sat between 19e and one west then up but more higher the closer to one west you go...then once you go past one west the higher the number goes west the lower it should then go...if you go past 19east the dish will go lower...then you will have to do the lnb skew.
TM500
DM500s
if i get motorised dish. will sats be picked up automatic or wil they have to be pre set
thanks for answering my qustions
Please Read Carefully!
No Sky UK NDS Videoguard Hacking Discussions.
Viewing Pay TV without a valid subscription is illegal
the files available are kept for experimental & educational purpose only
original vu duo2 /vu zero/ tm-nano-se. v-box / 36v /1.2 dish,
THANKS FOR INFO DO YOU KNOW A GOOD MAKE AND MODEL OF MOTOISED DISH
Triax 88cm dish{measures at 91cm}, a technomate 2200motor, darkgold 0.1db lnb, and 2 good set of t&k brackets...check out tringsat.com[the new starsat]
TM500
DM500s
Whats that all about mate?
Hi. Even a TM2600 motor is very good. Brand new around 50 quids. Easy to set up and operate. Use USALS to make your life easier. Regards.
Thread is 2 years old.
Oh thanks for that. I was only looking at the reply from this morning without realising how old this thread was...Do we know if Davey Ply managed to sort himself out?? Regards.
