dreamboxEDIT_5.0.0.0
Changelog:
5.0.0.0
- added completly new GUI with skinning support
- added transparency to crypto icon in main service list
- added transparency to dummy picon in bouquet panel
- added configurable color marker for selected services
- added proper handling of renamed alternatives
- added warning message if multibouquet is disabled on your dreambox
- added signal strength indicator
- fixed renumbering channel numbers after using "sort alphabetically" from context menu
- fixed when sorting by frequency now also sorting by polarisation is applied
- fixed problem with missing objects (service counter, profile selection)
- fixed cut&paste services with alternatives
- fixed saving of current profile when options panel is closed
- integrated language tool (Help -> Language Tool)
- removed LanguageTool.exe from installation package
- removed outdated help files
- language files updated
- some minor fixes
The the following features are only supported on genuine Dreamboxes with -Images based on Release 3.2 or higher
- full support for filtering of encrpyted services is now enabled
- full support for streaming services in userbouquets
- added video streaming support
Note: VLC 1.1.11 or higher is required, the installation directory is detected automatically, if you are using
a portable version set the VLC installation directory in the options panel.
- added support for taking snapshots of currently played stream
