Results 1 to 7 of 7
    world wide
    Default Audi A6 2.0 TDI DPF OFF, help
    Hi m8,
    This morning one customer cames to me with Audi A6 2.0Tdi from 2006,ECU EDC16 03G906016GB 1037380438, without particle filter. He removed it previously.
    I read software with Byteshooter and I modified it with ECU Safe 2.0, but still light is on and car hasn't power.
    Any ideea please?
    Can somebody help me with another modified software?
    Thanks,
    Member gka_3's Avatar
    Sep 2010
    Check this file.
    world wide
    thanks. i will check it and i will report
    world wide
    it is not working, same problem, light it is ON
    Oct 2011
    United Kingdom
    You must post here EEPROM from ecu with bdm then I can make proper Dpf off inside EEPROM is ash counter this need to be mod,
    Eco
    All DPF / FAP REMOVED MANUALLY
    TUNING ALL ECU INC EDC17 - SIEMENS - DENSO - HITACHI
    Jun 2009
    You don`t need change eeprom, ori flash modifed is enough
    super jumbe's Avatar
    Livingstone
    You could not be a bit clear to explain how?
