Page 1 of 3 123 LastLast
Results 1 to 15 of 35
    jackeldestripador's Avatar
    S.A.
    Default Golf TDI 0 281 308/309 no im*o start
    Does some one can help? I need to im*o off some Golf III TDI 1.9 with 0281001308/309
    inside 2 eeproms 93c46 and 2 uveprom B58157 (87C510)
  2. The Following User Says Thank You to jackeldestripador For This Useful Post:
    juanes 3 (5th January, 2017)
  3. #2
    DK Veteran klakier's Avatar
    Lubacz?w/Poland
    read 2x 93c46 I do immo off for you
    GG: 7541425
    I'm not Sharing Passwords!
    If my post was helpful,
    press "THANKS" button!!!!
    S.A.
    thanks, see attached files
    There is some procedure with the immo box?
    Lubacz?w/Poland
    Quote Originally Posted by jackeldestripador View Post
    your file off
    GG: 7541425
    S.A.
    Thanks pal, works really fine!!!!!
  7. The Following User Says Thank You to jackeldestripador For This Useful Post:
    kugglefischer (31st October, 2013)
  8. #6
    vanya86's Avatar
    Ljubljana
    I have some problem, if i can get pass. Thank you
    I do not use broken PAYPAL, i use Transferwise
  9. #7
    May 2009
    hi,i can get pass. Thank you
  10. #8
    vanya86's Avatar
    Ljubljana
    Default Golf 3
    Here is my file.
  11. #9
    Lubacz?w/Poland
    Quote Originally Posted by vanya86 View Post
    Here is my file.
    read another 93c46
    GG: 7541425
  12. #10
    vanya86's Avatar
    Ljubljana
    Default There you go.
    Here you go, this is eeprom near VACUM controler
  13. #11
    Senior Member djamelEZS's Avatar
    raely only 100% solution is to put immoff on immobox because may ecu on golfIII and it's better to put immobox off your file is on our forum digital-kaos
  14. #12
    Lubacz?w/Poland
    your file off
    GG: 7541425
  15. #13
    Lubacz?w/Poland
    Quote Originally Posted by djamelEZS View Post
    Why do you think ? That the better is make off in immobox? You have to two solutions off in golf III. I do, off in ecu or box depends on what part form car I get and two solutions are ok if you do good. Search you will find solution off to ecu on forum .
    GG: 7541425
  16. #14
    denmark
    Red face immo off 0281001308/309 in ecu
    hi can some help to turn off immo in ecu
    HELP HELP
  17. #15
    Member jpay2's Avatar
    Toulouse
    Default Hi need off
    Hi all, if possible just to put off with these dump thank you.
