Results 1 to 2 of 2
    DK Veteran fireblade1's Avatar
    Apr 2011
    looking up at the stars :)
    Default Fastest Rotating Star Found in Neighboring Galaxy
    This is an artist's concept of the fastest rotating star found to date. The massive, bright young star, called VFTS 102, rotates at a million miles per hour, or 100 times faster than our Sun does. Centrifugal forces from this dizzying spin rate have flattened the star into an oblate shape and spun off a disk of hot plasma, seen edge on in this view from a hypothetical planet. The star may have "spun up" by accreting material from a binary companion star. The rapidly evolving companion later exploded as a supernova. The whirling star lies 160,000 light-years away in the Large Magellanic Cloud, a satellite galaxy of our Milky Way.
    Astronomers have found the fastest spinning star ever discovered. The hot blue giant rotates at a dizzying 1 million miles per hour, or 100 times faster than our Sun does. The star is very close to the point at which it would be torn apart due to centrifugal forces if it spun any faster.
    Two researchers at the Space Telescope Science Institute in Baltimore, Md., Selma de Mink and Daniel Lennon, are part of an international team of astronomers who used the European Southern Observatory's Very Large Telescope at the Paranal Observatory in Chile to find the massive, bright young star, called VFTS 102. It lies in a neighboring dwarf galaxy, the Large Magellanic Cloud, about 160,000 light-years from Earth. Astronomers think that it may have had a violent past and has been ejected from a double star system by its exploding companion.
    The astronomers also found that the star, which is around 25 times the mass of the Sun and about one hundred thousand times brighter, was moving through space at a significantly different speed from its neighbors.
    "The remarkable rotation speed and the unusual motion compared to the surrounding stars led us to wonder if this star had an unusual early life. It was suspicious," explained Philip Dufton of Queen's University Belfast, Northern Ireland, United Kingdom, lead author of the paper presenting the results.
    This difference in speed could imply that VFTS 102 is a runaway star ***8212; a star that has been ejected from a double star system after its companion exploded as a supernova. This idea is supported by two further clues: a pulsar and supernova remnant in its vicinity.
    The team suggests that the star could have started life as one component of a binary star system. If the two stars were close, gas from the companion could have streamed over and in the process the star would have spun faster and faster. This would explain one unusual fact ***8212; why it is rotating so fast. After a short life of about ten million years, the massive companion would have exploded as a supernova ***8212; which could explain the supernova remnant found nearby. The explosion would have led to the ejection of the star and could explain the third anomaly ***8212; the difference between its speed and that of other stars in the region. As it collapsed, the massive companion would then have turned into the pulsar that is observed today and completed the solution to the puzzle.
    Although the astronomers cannot yet be sure that this is exactly what happened, Dufton concluded, "This is a compelling story because it explains each of the unusual features that we've seen. This star is certainly showing us unexpected sides of the short but dramatic lives of the heaviest stars."
    To test this theory, Lennon and de Mink will use NASA's Hubble Space Telescope to make precise measurements of the star's proper motion across space.
    This research was presented in a paper in the Astrophysical Journal Letters.
    HubbleSite - NewsCenter - Fastest Rotating Star Found in Neighboring Galaxy
    fireblade.
    for the latest space news and get the latest updates on space flight and other space stuff visit this site.
    http://www.nasa.gov/home/index.html.
    Want to know more about 9/11 the lies. Hollow towers. The fake media videos and other things to do with 9/11 check out this link.
    http://letsrollforums.com/index.php
    Canker_Canison's Avatar
    12th Level of Hell
    I'm going to be an anal retard.....
    There can't ba a centrifugal force as mentioned in the opening text. That would mean something is acting on the expansion to push it back towards the star.
    Don't think gravity counts in this case.
    The correct word would be centripetal, in this case the rotational force pushing the mass away from the star.
    brilliant scientists, dumb reporting. Not you FB, I know you're really Steven Hawkins assistant.
    Canker
    "Animal, vegetable or mineral... I'll do anything, to anything, with anything"
    - The Baby Eating Bishop of Bath & Wells
    [COLOR=Green]
