im on xp,same shite again,redsnow keeps hanging up on first stage,im done for tonight will have another go at this tomorrow
The control of information is the consolidation of power
?I care not what puppet is placed on the throne of England to rule the Empire. The man who controls Britain?s money supply controls the British Empire and I control the British money supply.? ? Nathan Rothschild
IF I HELPED HIT THE THANKS BUTTON
when it says release home button keep it presses it worked for me
ive tried again this morning,but im having two problems
the first is with ifaith,im trying to save the blobs,but when it gets to the "recognise ios" section it hangs for ever,same as yesterday
i close it down unplug the phone switch phone back on and its fine
same issue with redsnow,on the first stage it hangs,left it for ages but no joy whatsoever,unplug the phone switch it on and its fine,,if i restore the phone to a custom ipsw 5.0.1 will this make any difference ? it seems strange that this phone is only a week old from 3 and i cant jb it but my identical phone is fine
any advice most welcome
search for a 5.0.1 restores Ipsw and Download that as its going to be older than downloading there's from iTunes and restore to that , just incase they have added anything , thought we would ok heard more tho if that was the case tho
iREB R5, RC4, RC3 for iOS 5.0.1, iOS 5, iOS 4.3.3, 4.3.x, 4.2.1, 4.x.x to fix following iTunes errors: 1604, 1601, 1600, 16xx etc while restoring custom iOS 5.0.1, 5.0, 4.3.3, 4.3.x, iOS 4.2.1 or 4.x.x firmware
http://downloads.ih8sn0w.com/iREB-r5.zip
Prevent iPhone4 Baseband Update
UPDATE: This method WILL work for iPhone 4 RESTORING to 4.3
This page ONLY deals with iPhone 4 baseband protection. I'm sorry this will not work for any other device.
You can protect your iPhone 4 BB restoring to iOS 4.2.1. Follow these steps exactly:
Get the latest TinyUmbrella.
Get the latest greenpois0n rc5 update (Greenpois0n.com)
Open TinyUmbrella
Plug in your device and save SHSH (make sure 4.2.1 SHSH were saved, if not don't bother continuing)
Start TSS Server (If you get errors read the help section or FAQs or comment below typically it fails because you have some kind of web sharing enabled... use google to fix it - your issue really not much I can do...)
Open iTunes
Select your device in iTunes
Shift(windows) / Option(Mac) restore -> Select the 4.2.1 ipsw
Restore SHOULD error with a 1013 error. Click the "ok's" and close iTunes.
With your device sitting with the usb pointing to iTunes (recovery mode), enter DFU by pressing and holding HOME + POWER until your screen goes black... then after a count of 2 (1.5-2 seconds) let go of POWER but keep holding HOME. If all goes well you will see nothing but a black screen. If your timing is even a LITTLE bit off, you will see the apple logo and your phone will boot back into recovery mode... Go back to step 10 and try again.
You're now in DFU mode. Start greenpois0n and press 'Jailbreak'
Once greenpois0n has finished its thing. Press 'Complete!'
Let your device restart. You should end up on the activation screen.
Congrats your baseband was preserved and you are now on 4.2.1
Put your device into DFU mode and then click 'Fix Recovery'
Click 'Yes'
Your device's screen will turn white and you'll see debug boot information.
Eventually your device will boot into the activation screen.
Congrats. You're on 4.2.1 (again)?
If you get a 16XX error then try entering DFU and go to step 5.
If your restore does NOT end in a 1013, it means your baseband was updated. This is likely because you did not have the TSS server running OR you updated without TinyUmbrella OR you are working with a device OTHER than iPhone 4.
windows version http://cache.firmwareumbrella.com/do...la-5.10.06.exe
MAC version
http://cache.firmwareumbrella.com/do...la-5.10.06.pkg
Go Jailbreak your iPhone 4s and iPad 2 NOW
Chronic Dev and iPhone Dev and a bunch of other 'associated' individuals came together to knock out the a5 installment of the corona untether. The new tool is called absinthe and you can get it here:
Greenpois0n.com
Download the latest tinyumbrella and save your blobs first..
Assuming you have a clean copy of 5.0.1 saved on your computer....need to put your iPhone into DFU....download the latest Redsn0w( beta 5) in extra follow the DFU instruction...don't be a wuss press the BUTTONS in Time and FIRMLY...
Fire up tinyumbrella in the "Advanced" tab uncheck to get a clean Restore...close tinyumbella..
Fire up iTunes it should detect your iPhone in DFU mode...
Hold "shift" button and press Restore..
Select your clean copy of IOS 5.0.1 and restore..
If it gets through without errors it's 5 min with Redsn0w to jailbreak...
Funny...in the last couple of hours I've managed to Restore and jailbreak my iPhone three times, trying to track down an Apple Boot looping problem....prepared to go through this one more time before I throw in the towel... It's all sent to test...
