Page 2 of 9 FirstFirst 1234567 ... LastLast
Results 16 to 30 of 128
  1. #16
    Has any one try the 2902192 PDI acert file if so how did it go ? smoke ? clean ? fuel mileage ? and POWER
  2. #17
    australia
    Quote Originally Posted by cheesey View Post
    Thats funny, we got 580hp to the wheels with that same file,hot numbers and a resistor. It smoked like hell,but that an aussie file.
    Hey Leigh, you said you work at Dave's Diesel Repair in Acheson,Canada. Must have did some injector work to get those numbers
    well all you bloke need is 625 hp and 4.56 diff and you will cruise up thoses big hills you have over there real easey,, after all its about average time and good fuel miledagewe pull 6 decks of cattle here in aussie on the flats no worries at a 60 mile ahour ...around 150 ton all up with fat bullocks
  3. #18
    Member frank antonio ruiz de la's Avatar
    Jan 2011
    mexico
    cat engine 3176e files? please
  4. #19
    Top Poster + sugiyono's Avatar
    Oct 2011
    pls go to the below link
    http://www.digital-kaos.co.uk/forums/f165/caterpillar-flash-files-111535/index24.html
  5. #20
    I'm calling Alligator on bullsh!t. Don't talk it up mate, we're all on here to help each other out, not make up crap about how good we are. You didn't blow nothing up with that file!!
  6. #21
    Nov 2010
    I tried the 1739454 in my truck and it runs a lot different then a normal 7CZ or 1MM brakesaver file. It will breakup at 2300rpm with it and it idles differently then before and I don't mean because it has added timing It idles higher then 600 when that's where i have my idle set. With regular 600 file it has a lopey idle.
    Here's a link of my taking off with the 1739454 file
    2000 Western Star Accelerating on the Street - YouTube
    Here's a link of how it idles with a regular 600 file, I don't have a video of it idling with the 1739454 file yet.
    Starting 2000 Western Star with a Cat - YouTube
  7. #22
    Awesome lope!!! You must be running different injectors??? My 14l series 60 will break up like that if I raise the rpm limit above 2100. What turbo you running?
  8. #23
    Nov 2010
    Yeah I'm running larger injectors. Still running stock turbo though . I've gotten 16.2 @87MPH with the stock turbo though. Was waiting to do some other changes before I get a bigger one.
  9. #24
    Oct 2011
    I want flash Caterpillar-flash-files year 2008, who know to guide, plse...thanks
  10. #25
    Jun 2011
    Quote Originally Posted by muz79 View Post
    HEY muz79, no bullsh!t........ It was my engine and the bill to replace the pistons and scored liners. I can show you the dyno run and how the crankcase pressure sky rockets off the page while its cranking out 2400ft/lbs, Dont believe me? keep installing that file.... id hate to be you after you toast someones engine. Lesson to all.... learn from my misfortune and stay away from these files!!
  11. #26
    Junior Member Sledman's Avatar
    Feb 2012
    Quote Originally Posted by ashkar View Post
    Can you advise which file that did this? I am having issues with the 270-7127 file....
  12. #27
    Nov 2010
    Quote Originally Posted by Sledman View Post
    He's talking about the 173-9454 aussie file
  13. #28
    australia
    well some ****er here like black smoke- they been sticking 4242 injector code in the old 5ek engine and loseing 2 gear on the hills- so right code pulls like a train all day long
  14. #29
    australia
    look in 2007 flash file. airport fire trucks 650 to 700 hp on that disco
  15. #30
    Yeah post it up. Also what injectors are you running in your 6NZ and what calibrations are they set to?
    What i'm not understanding is how there are people on other forums who are making every bit as much as you did (some 800hp) with 6NZ motors using PDI files, yet your motor blew after one dyno run???
    Also what was the EGT during the run and do you have the stock turbo and if not, what turbo are you running?
