Page 3 of 3 FirstFirst 123
Results 31 to 42 of 42
  1. #31
    Senior Member dfi's Avatar
    Sep 2008
    Romania
    Answer is a LITTLE delayed... , but could still ***8203;be useful.
  2. #32
    DK Veteran mouss's Avatar
    Feb 2011
    french
    hello
    here is forum so why you don't post your solution here for all member??
    thank
  3. #33
    You can read ecu by obd tuning tool
  4. #34
    Aug 2011
    flash.... and eeprom?
  5. #35
    May 2014
    It is easy.Do reprog. with Renault Clip and on the end type details witch program will ask you (etc.cruise control,milage,injection codes...) manualy -not copy previosly saved files.
  6. #36
    Jan 2013
    istanbul
    today I did 3 fuleance dash +abs + ecu dcm 3.4 and megane sid 305 km ok cange km
  7. The Following User Says Thank You to YILDIZ OTO For This Useful Post:
    Mohssine (21st January, 2018)
  8. #37
    Jan 2013
    istanbul
    arkadas lar ben fuleance megane
  9. #38
    Jan 2013
    istanbul
    Default DCM CLiO OK 95080
    DCM12 CLiO TAMAM KM83000
  10. #39
    Jan 2017
    Bonne journée, tout le monde peut aider ...
    Voiture: Renault Kangoo 1.5 dCi
    Année: 2011
    ECU: DCM 3,4
    mémoire: S95640
    Km maintenant: 325.XXX
    Km Nècessaire: 246.XXX ou 0
  11. #40
    antenor's Avatar
    Here
    If i help, d'not forget to press thank button!!
  12. The Following User Says Thank You to antenor For This Useful Post:
    Mohssine (28th January, 2018)
  13. #41
    Fec001's Avatar
    Default Dump
    Hi!
    Please correct km in this dump. I can't check main odometer because I haven't got clip. Launch shows 207850 km - "Km since last successful regen."
    Dash shows 128xxx km.
    Please correct main odometer and DPF releated km data.
    Need correct solution because I can't verify with diag
    Many thanks!!!
  14. #42
    antenor's Avatar
    Here
  15. The Following 2 Users Say Thank You to antenor For This Useful Post:
    DashProg (27th September, 2022), Fec001 (1st February, 2018)
