hello
here is forum so why you don't post your solution here for all member??
thank
hello
thank
You can read ecu by obd tuning tool
flash.... and eeprom?
It is easy.Do reprog. with Renault Clip and on the end type details witch program will ask you (etc.cruise control,milage,injection codes...) manualy -not copy previosly saved files.
today I did 3 fuleance dash +abs + ecu dcm 3.4 and megane sid 305 km ok cange km
Mohssine (21st January, 2018)
arkadas lar ben fuleance megane
DCM12 CLiO TAMAM KM83000
Bonne journée, tout le monde peut aider ...
Voiture: Renault Kangoo 1.5 dCi
Année: 2011
ECU: DCM 3,4
mémoire: S95640
Km maintenant: 325.XXX
Km Nècessaire: 246.XXX ou 0
If i help, d'not forget to press thank button!!
Mohssine (28th January, 2018)
Hi!
Please correct km in this dump. I can't check main odometer because I haven't got clip. Launch shows 207850 km - "Km since last successful regen."
Dash shows 128xxx km.
Please correct main odometer and DPF releated km data.
Need correct solution because I can't verify with diag
Many thanks!!!
