Mohssine (21st January, 2018)
You have solution for change in ECU??
What memory have this ecu?s??
MEMORY IS 95320 EEPROM
hi guys, I am sorry for my stupid question, but now for that new meganeIII... will I need to change km in dash+ABS+ECU not only in the dash+ABS as usual ??
<< KEEP LEARNING W.O LIMITS >>
2 Simple Methods To Say Thanks on DKPress Thanks _OR_ Add Rep
benz auto (24th May, 2014)
hello M8
the memory in ECU (delphi DCM 3.4) is 95640, if you change km in the abs + dash
the original value remains in the ecu
regards
dear pink,
if you change the odo in dash + abs ,your work is parzial ok,no errors ,but if you connect the can clip with car,in the parameters you see the original value(only in ecu motor) like my first photo,second photo is the solution
regards
hello pink
you are welcome
tony59
[QUOTE=tony59;1412054]hello M8
in the new megane III with ecu delphi dcm 3.4 the km are in ecu and when you connected the clip they are displayed (see attached photos).
I have the solution and if you need i will help you,post your dump here......[/QUOTE
Is it value exact like on the dash show?I asked because in some cars motor ecu take km from dash.Try to disconect dash and see what is hapened with km inside ecu
Can UPA be used to read this using the eeprom spi lead and read as a ST95640
hello cricstudio,
my solution is for ecu DCM 3.4 with eeprom 95640 , your dump is for dcm 1.2 eeprom 95080,sorry but I am not solution for this
regards
