Page 2 of 138 FirstFirst 12345671252102 ... LastLast
Results 16 to 30 of 2067
  1. #16
    vanos batam's Avatar
    Batam-Indonesia
    Default the key unused calculate
    188BE890C3EF778A ? Key is not used
    2. D3C455A3FB909B1B ? Key is not used
    3. 2FD1E80C0006A1C6 ? Key is not used
    4. D3EAFB5E4A82D4E2 ? Key is not used
    5. BE1B9027CE8CD574 ? Key is not used
    6. 8B99AEF7A9C30B19 ? Key is not used
    7. 48C5307FF38E2838 ? Key is not used
    8. 0EBEA047C505C683 ? Key is not used
    KeySet ID: D0B35485again to compare above the dump
    _______________ D3-oToprog _________________
    ig : vanos_batam
  2. The Following 8 Users Say Thank You to vanos batam For This Useful Post:
    antonypaul (22nd July, 2023), Col19 (16th December, 2020), Dajan2009 (19th October, 2015), ecumasters (29th April, 2016), giovani (29th August, 2013), mechatronics (6th February, 2016), Talleresmalaga (1st May, 2020), zas010970 (5th June, 2017)
  3. #17
    Key_0..Key_3 - used
    Key_4..Key_7 - unused
    Your Dumps (1D59J = 1D59J_unused) are the same. And where Key_0 ?
  4. The Following 2 Users Say Thank You to Label55 For This Useful Post:
    giovani (29th August, 2013), zas010970 (5th June, 2017)
  5. #18
    bram380's Avatar
    Indonesia +628153111774
    Quote Originally Posted by vanos batam View Post
    HERE THE DUMP FROM online KEYS GENERATOR
    from orugynal dump
    HASH and KEYS
    1. 88BE890C3EF778A ***8212; Key used
    2. D3C455A3FB909B1B ***8212; Key used
    3. 2FD1E80C0006A1C6 ***8212; Key used
    4. D3EAFB5E4A82D4E2 ***8212; Key used
    5. BE1B9027CE8CD574 ***8212; Key is not used
    6. 8B99AEF7A9C30B19 ***8212; Key is not used
    7. 48C5307FF38E2838 ***8212; Key is not used
    8. 0EBEA047C505C683 ***8212; Key is not used
    KeySet ID: D0B35485
    Key1,2,3,4 can change to be Not Used by change bit to FF at address 25
    Key Status: 25
    Code--> Status Used KeyNo.
    FF ---> BLANK (all key Not Used)
    00 ---> 0,1,2,3,4,5,6,7 (all key Used)
    01 ---> 0,1,2,3,4,5,6 (7-keys used)
    03 ---> 0,1,2,3,4,5 (6-keys used)
    07 ---> 0,1,2,3,4 (5-keys used)
    0F ---> 0,1,2,3 (4-keys used)
    etc....etc...
    XX = 8421 8421
    FF = 1111 1111
    00 = 0000 0000
    01 = 0000 0001
    03 = 0000 0011
    07 = 0000 0111
    0F = 0000 1111
    I think with change address 25 to FF dump EIS is blank, so OLD Key can be reused.
    But i don't test it.
    Any idea about this opinion?
  6. The Following 8 Users Say Thank You to bram380 For This Useful Post:
    Col19 (16th December, 2020), giovani (29th August, 2013), hamzadaw2000 (8th September, 2013), mechatronics (6th February, 2016), richard27 (28th February, 2018), sweetsamo (9th February, 2015), zas010970 (5th June, 2017)
  7. #19
    In deciding whether a key is used or not, determine the value of Hash_key_0_7, not cell addr.25. Addr.25 shows only information about the keys.
  8. The Following 2 Users Say Thank You to Label55 For This Useful Post:
  9. #20
    Here is some basic information:
    Old EZS (W202, W208, W210, W220 ..) have two code generators - a key code generator 8 bytes) and generator ECU code (6 bytes).
    New (W203, W209, W211, W639 ..) have only the key code generator.
    HASH key consists of 8 bytes, that is, the entire table contains 18445618199572250625 codes.
    For each key are assigned 196607 codes.
    All keys assigned are the same table, except that everyone starts from somewhere else.
    |>-----> 18445618199572250625_table_codes->--- .... -->------------->|
    |<-<-196607_key_codes-<-<|
    For further considerations we need to use the dump, which will generate eight keys (here, no key_0).
    This should be good. Could someone generate eight keys to the attached dump?
  10. The Following 6 Users Say Thank You to Label55 For This Useful Post:
    Col19 (16th December, 2020), giovani (7th May, 2013), mcday (16th October, 2014), redful (28th April, 2015), tihiuvek (30th October, 2015), zas010970 (5th June, 2017)
  11. #21
    Quote Originally Posted by bram380 View Post
    Key Status: 25
    etc....etc...
    XX = 8421 8421
    FF = 1111 1111
    00 = 0000 0000
    01 = 0000 0001
    03 = 0000 0011
    07 = 0000 0111
    0F = 0000 1111
    this dump from Label55
    I activated all the keys
  12. The Following 7 Users Say Thank You to andrey3 For This Useful Post:
    Col19 (16th December, 2020), giovani (29th August, 2013), janjamnicky (4th September, 2016), mcday (16th October, 2014), mechatronics (6th February, 2016), redful (28th April, 2015), zas010970 (5th June, 2017)
  13. #22
    what algorithm is used to calculate the hash for key?
    sh1? md4? md5?
    structure of the key is:
    EZS Pass, SSID, Start hash - All this is in the EZS
    but how get other hash?
    they are derived from Start hash or Start hash + SSID+... ?
  14. The Following 3 Users Say Thank You to andrey3 For This Useful Post:
    stickmuon (11th September, 2016), zas010970 (5th June, 2017)
  15. #23
    Hi andrey3.
    Dump "Used corr.bin" nothing has changed. Still 3 keys are used, and the others not. Changed only the starting point of 0,1,2 keys. And this is a serious mistake.
  16. The Following User Says Thank You to Label55 For This Useful Post:
  17. #24
    Batam-Indonesia
    Quote Originally Posted by Label55 View Post
    F9E17A886A2DE188
  18. The Following 3 Users Say Thank You to vanos batam For This Useful Post:
    ecumasters (29th April, 2016), mechatronics (6th February, 2016), zas010970 (5th June, 2017)
  19. #25
    To file "USED.rar" were generated keys (of which 3 are used, and other not). Many thanks to VANOS, for their providing.
    And now, let's change the status of all keys - all used.
    For this purpose, we change all the hashes.
    Is calculating keys to the this dump, SKC will change the contents of the dumps 8 keys?
    Can someone again generate eight keys for the new hashes? (This is the last time).
    "ALL_USED.rar" <--- For this file, generate the keys.
    I'll explain it later.
  20. The Following 5 Users Say Thank You to Label55 For This Useful Post:
    Col19 (16th December, 2020), mcday (10th February, 2016), mechatronics (6th February, 2016), teeone (15th November, 2017), zas010970 (5th June, 2017)
  21. #26
    Batam-Indonesia
    from mcu 192331
    KeySS ID: 709DC73C
    1. A95FF3AD946F1E78 ? Key used
    2. 2721476D7713F302 ? Key used
    3. B5581FD5EF5B4C67 ? Key used
    4. 1A7BF1890C547AA7 ? Key used
    5. EF4CDC86402EE234 ? Key used
    6. 1FB7D6F8714E4295 ? Key used
    7. FE8ADAEC94B2426B ? Key used
    8. 69BDC40EDE6B41B6 ? Key used
    again
  22. The Following 2 Users Say Thank You to vanos batam For This Useful Post:
    ecumasters (29th April, 2016), zas010970 (5th June, 2017)
  23. #27
    user2468's Avatar
    Planet Earth
    please can you generete key from this dump
  24. The Following User Says Thank You to user2468 For This Useful Post:
  25. #28
    SKC-Continued....
    Key Table consist of 196607 codes (from 1 to 196607).
    After inserting the key to the EZS, the code counter decreases by 1, and Key sends the latest code from the table. So the codes are sent in the order- from the end to beginning of the table (196607, 196606, 196605...0).
    EZS saves only the last four codes, in the order of 1, 3, 7, F, where "F" means the last generated.
    After turning the key in the IGN position, recently accepted key code is sent to the ECU (this method is valid after 1999 years.).
    For the old solutions (to 1999 year) this is carried out differently.
    After turning the key in the IGN position, ECU sends two bytes of code. EZS in response sends six bytes of code (Compatible with ID_ECU_OLD).
  26. The Following User Says Thank You to Label55 For This Useful Post:
  27. #29
    bram380's Avatar
    How to repair EZS/EIS "HASH ERROR" ?
    See detail below:
    [ame="http://www.youtube.com/watch?v=l6LU9Gz5-zM"]How to repair Mercedes Benz W210 EZS Hash Error.wmv - YouTube[/ame]
  28. The Following User Says Thank You to bram380 For This Useful Post:
  29. #30
    bram380's Avatar
    After trying to discuss about Benz SKC in mid month,
    the price Benz SKC (clone) becomes $1,000
    Price drops are pretty good...
    need more thinking before buy clone...!!!
    see report here:
    Benz SKC Clone
  30. The Following 2 Users Say Thank You to bram380 For This Useful Post:
    meansure (16th July, 2018), zas010970 (5th June, 2017)
