Clone Duo Open pli (kernal 3.0)Oscam-cccam sky uk Cooltv - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 30 of 30
  1. #16
    Top Poster Data7's Avatar
    May 2009
    Wigan
    oscam.user =flines ie you give
    oscam.server =clines ie you take
    look at the file i gave a link to.
    oscam.user
    [account]
    user = mym8
    pwd = XXX~~~~13e
    description = any description you want
    group = 1
    uniq = 1
    cccignorereshare = 0
    send me your msn and i will see if i can help you better.
  2. #17
    so i won't need to use cccam when iv done that and when i have done that should it work mate,Im not on man mate but you can have my email if you want.
    thanks pal
  3. #18
    May 2009
    Wigan
    it is far quicker to be on msn and get it sorted real time rather than wait for you to find open read anawer the email
  4. #19
    i will try and get msn mate
  5. #20
    May 2009
    Wigan
    no problem m8
  6. #21
    May 2009
    Wigan
    This is taken from another forum.
    Here are the contents of my four files:
    This for Sky UK card in upper card slot with Oscam5953/CCcam213. This is running under Blackhole 1.6.5 but I don't imagine Vix it too much different.
    There are 4 files:
    CCcam.cfg in /etc
    oscam.conf, oscam.server & oscam.user all located in /etc/tuxbox/config
    CCcam.cfg (if you are already running CCcam, back up your working settings BEFORE you install the new cam).
    BOXKEY: /dev/sci0 XX XX XX XX
    SMARTCARD CLOCK FREQUENCY: /dev/sci0 3570000
    N: 127.0.0.1 12000 test1 test2 01 02 03 04 05 06 07 08 09 10 11 12 13 14 256
    (I left my boxkey in initially so that this file would work with both CCcam alone or OscamCCcam but you can remove that line later if you want, once you get it all working)
    oscam.conf
    nice = -1
    WaitForCards = 1
    logfile = stdout
    preferlocalcards = 1
    saveinithistory = 1
    [webif]
    httpport = 8888
    httpuser = admin
    httppwd = admin
    httpallowed = 192.168.0.100-192.168.255.255
    # protocols
    [newcamd]
    key = 0102030405060708091011121314
    port = 12000@0963:000000;12001@0963:000000
    (the line httpallowed includes all private network IP adresses or you can just replace this with the ip address of your box. This will allow you to look at the web interface via your browser so if the ip address of your box is 192.168.2.10 then in your web browser you would type 192.168.2.10:8888 (8888 is the port number that it is using). The username and password are both "admin".
    oscam.server
    [reader]
    label = slot1
    protocol = internal
    device = /dev/sci0
    boxid = 00000000
    blockemm-u = 0
    blockemm-s = 0
    blockemm-g = 1
    blockemm-unknown = 1
    emmcache = 1,3,2
    group = 1
    caid = 0963
    (Whilst this config does not require a boxkey, I found that it will not work if you completely remove this line. I just put 8 x "0" here and it works for me).
    oscam.user
    [account]
    user = test1
    pwd = test2
    monlevel = 0
    uniq = 0
    group = 1,2
    au = 1
    caid = 0963
    Make these 4 files, and place them in the folders I have mentioned, either with explorer or with FTP. When you have copied the files there, double check that the permissions are correct. With Filezilla, right click the files, and make sure the numeric value is set as 755 Double check the permissions for /etc/tuxbox/config are the same also. If you use Windows Explorer, right click each file (and the Config Folder) and make sure the read/write permissions are the same. Then go in and make sure that oscam/cccam is set as your default cam.
    Switch your box off, and then back on again and let it start up. I shut my box down on one of my subscription channels and thought it wasn't working because the picture didn't clear instatly, but it took a couple of minutes to sort itself out and clear the my subscription channels. This delay is only for the first time you start the box. Further shutdowns and restarts clear subscription channels almost instantly.
    If it clears OK then you can view your entitlements via the web interface.
    Hope this is of some use.
  7. #22
    ill try that pal thanks
  8. #23
    hi mate i have done all this and its saying in oscam.ms) (of 0 avail 0) (no card support 0963:000000)
    Its clearing channels but not sport.
  9. #24
    V.I.P. Member mdt's Avatar
    Feb 2009
    bolton, north-west. uk
    Quote Originally Posted by madmanuk View Post
    try oscam 6059... is it saying card or network when it clears a channel? regards mdt
    DM800HDSE SIM 2.10. SSL84D OPEN-ATV ORBITAL 80CM/DARK MOTOR/IBU/53E-30W
  10. #25
    in oscam its saying no card support mate
  11. #26
    ok i have got it running now with the files of a 500 that was running oscam/cccam and it seems ok,Its setup in my living room but when its gets moved to a new location on my network oscam won't work and i don't know why, its only been moved 30 feet away,?.Running Oscam5953/CCcam213
    ps
    where do i look for the ECM times.
    thanks lads
  12. #27
    Jul 2012
    Will this also work with a genuine VU+ SOLO 2?
  13. #28
    try it mate
  14. #29
    Jul 2012
    I am new to all this so my question is if I input all the text you wrote into telnet will it do whats needed for all sly channels to unlock as thats what I am after its just for testing out what the box can do though and I have a vu+ solo 2
  15. #30
    Jul 2012
    Anyway I tried this image and for some reason all the FTA channels dont work well on my genuine box but all the extras in this image make it super so I wish it worked on my unit
