Page 8 of 26 FirstFirst ... 34567891011121318 ... LastLast
Results 106 to 120 of 380
  1. #106
    Quote Originally Posted by Alligator View Post
    You won't touch the data eh? Well I guess I know what level your on...LOL
    Just to clear up the Data Block!!! First of all you didn't underline the whole serial number and left out 1/2 a byte. LOL
    Seeing your so clever why didn't you post the whole File? LOL Do you think everyone is dumb?
    I think Underpsi is right your Cocky and maybe your name is Louis.
    Here is the complete file!!!
    <?xml version="1.0"?>
    <XMLFILE>
    <Header>
    <FileInfo>
    <FileVersion>1</FileVersion>
    <FileIdentifier>3875</FileIdentifier>
    <FileType>ETrim</FileType>
    </FileInfo>
    </Header>
    <OnboardData>
    <DataType>C200</DataType>
    <DataIndex>FFFFFFFF</DataIndex>
    <DataChecksum>FFFFB0F6</DataChecksum>
    <Data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ata>
    <AdditionalInformation>
    <UserVersion>0</UserVersion>
    <InjectorSerialNo>5A50943186B9</InjectorSerialNo>
    <ETrimLockVersion>0300</ETrimLockVersion>
    <ECode>8329</ECode>
    <InjectorPartNum>2490709</InjectorPartNum>
    </AdditionalInformation>
    </OnboardData>
    </XMLFILE>
  2. #107
    May 2011
    Quote Originally Posted by Far_Call View Post
    <XMLFILE>
    <Header>
    <FileInfo>
    </FileInfo>
    </Header>
    <OnboardData>
    <ECode>8329</ECode>
    </OnboardData>
    </XMLFILE>
    Do you know how bad you look? You didn't even ask for the whole file. Your a terrible actor.
    I guess thats what you call doing it big time in pull-ups.
    Seriously 1/2 byte? <wrong it's BASE64.
    Do you know anything about coding? Tell me what kinda of data it is.. Then share with dk what the data is?
    What angle do you cut 3406E needles? What is the minimum leakage allowed by factory between the needle and housing?
    In PPH what does a 248-1394 flow, highest to lowest point?
    What PPH size of tip do you need to achieve 998cc.<600hp rating. What is the leakage allowed by the spill valve?
    I think your dumb for trying to prove a point that can't be proven (trying to make you look better)Since you insist on voiding the question. What is the data. (whole function)
    It's not about egos! Were talking about injectors!
  3. #108
    May 2011
    There is too many variables in any given injector to worry about time wise to have them all on the same trim. Again it defeats the purpose of Trimming for the reason it was designed. I usually set mine to as many as 6 levels depending on the application and total HP. When working with Tip that flow 12 kilo/min you get a very large % of fuel variation at 18mm of Rack by way of Trim. In comparison to a STD C15 with 2.828 Kilo/min with 11 mm of rack.
    You can talk about the data block anytime you like!!!
    Changing the Serial # in the Trim file "Additional Information" block does not alter the data block or the serial within the data block hence ET shows all the same serial.
    However the Oscilloscope will show the wave form and its variations in Pilot Injection through to its Post Injection depending on what Flash file its using and what Trim file you use. What the trim file can do and what the Flash file uses can be two different things as Cat does not in most cases use all of its Patent functions.
    If you didn't go to university for this you shouldn't bother.... I wanna talk data of the injector? Oscilloscope theres no need for that if you can open/read/etc. The oscilloscope is a built in function. We could talk about the 22 point break down of what you see on the oscilloscope but we would be going backwards. We've moved passed that were on the data now I feel like im saying the same thing over and over because I am.
    You say it's time consuming to get them all on the same trim, I ask what are you doing wrong? Are you reusing parts or do you at least send them out to get changed to a better specifiation of your liking?
  4. #109
    May 2011
    Quote Originally Posted by Underpsi View Post
    I didn't say you're just changing the tips if you read my post right. I said I hope you're doing other things and NOT just changing/honing the tips. I also didn't say I know what I'm doing with injectors (internally). You're still talking that you can build so much hp just by trim codes which is obviously bogus.
    I don't know where you think I buy my stuff from but I can bet its not from where you think!
    My biggest question is if you're so good why doesn't everybody know about you? If you knew you were good and everyone who bought your stuff knows it than it wouldn't take long for everybody to want your stuff.
    Unless your name is Louis then I have no idea why you're so cocky.
    My apoligies, your emotions were not coming out of the post like this one. So, I am afraid to tell you It's after the injector is complete that the trim coding comes in effect.
    Louis? Can't say I know a Louis.
    Everyone would want my stuff? I'm not some kinda slut.
    stuff. I'll stuff it in. looks like it needs a new plug.
    Underpsi, do you know who does the casting for the injectors? Because if you did you would want alll his stuff! lmao.
    I'm not trying to sell injectors on dk. DUH!
  5. #110
    May 2011
    Far_Call,
    Do you sell single injectors, or only in sets?
  6. #111
    May 2011
    <XMLFILE>
    <Header>
    <FileInfo>
    </FileInfo>
    </Header>
    <OnboardData>
    <ECode>8329</ECode>
    </OnboardData>
    </XMLFILE>
    Your pedistle must be a booster seat. I can't belive you got 2 "thanks". Seeing that I shared 30,000 files and this being one of them you could have looked it up on DK.
    You must be real clever
    So, that being said it was a random file selectednaw naw naw nuh.
  7. #112
    Aug 2011
    USA
    So does anybody need injector trim files or is forum for a pissing contest now ?
  8. #113
    Quote Originally Posted by cnckulp View Post
    Point taken and please accept My apologies.
  9. #114
    Jun 2011
    Noooooo!, this is a wicked learning session, who doesnt want to learn about the data? Im hoping Far_Call or Alligator will school us with there knowledge!
  10. #115
    Aug 2012
    alligators post #85 tells enough info in it for a lot of discussion alone. Thanks
  11. #116
    Jul 2012
    Bel air MD
    The cat sdp trims are a little different the files start with 6c. The rack measurement Is way higher when watching stats. I wonder why? I know the fuel pump flows twice the flow rate. But the rack movement why?
  12. #117
    Aug 2012
    Having the same File in each cylinder is a simple task as you know and we have all done years ago but its not correct way to do it and that is probably why Cat went this way. Muddy the water to trick people into thinking they cant do it. Its no big deal to do it but Why do it?
    We can all overhaul the injector to make them all flow identical cc to within as much % as you like but that defeats the purpose of the trim codes and whey they were introduced.. ...The means of electronically adjusting the injector allow for variabilities in manufacture.
    The trims also allow for adjustment due to normal wear, no?
  13. #118
    Help! I need the trim file for injector part
    A550358380A9
  14. #119
    Top Poster peter21's Avatar
    San Miguel, SV
    Default C7 trim file
    hi guys, can someone helpme with this trim file code for C7...
    3B1019824679 ... thanks in advanced....
  15. #120
    Top Poster + shisik's Avatar
    Sep 2011
    RUSSIA St. Petersburg
    30 000 trim files
    TrimFiles.rar
  16. The Following 6 Users Say Thank You to shisik For This Useful Post:
    apr73 (5th December, 2014), joeseph666 (29th June, 2013), mang5087 (30th January, 2014), melgarejo.salomon (11th August, 2017), mikolka (28th November, 2013), peter21 (1st May, 2016)
