Format drive to fat 32 maybe.
if that does not work open up the tm and see if the capacitors are bulging they are the transitors that look like little cans if they are bulging they need replacing you can get them of tm
a higher temp.resistent one are availble now and a soldering iron will only cost you a few quid if you do it yourself
Everything discussed on this forum is for experimental and educational purposes only. Use the information at your own risk.
The receiver does run very warm. I switched it off earlier to let it cool. When I switched it on again for a few minutes the pictures on all channels were very jerky, but problem stopped after about 5 minutes as if warming up settled it. Still no USB recognised though.
I will open it up and check the capacitors.
Couldn't see no bulgng capcitors or any other damage to ciruits. But receiver took 5 minutes again before picture would stop jerking, also during this time the light on usb flash drive didn't work but came on same time as picture settled, receiver still doesn't see the usb drive though.
give technomate a buzz they might have some idea
