humax foxsat extra sats
Results 1 to 4 of 4
    Member edward hitler's Avatar
    Sep 2008
    Default humax foxsat extra sats
    Recently found out that my freesat box has a hidden menu that allows me to change the set up of the dish to a motorized dish and it has a list of satellites. If I got a motorized dish what channels would be freely available? It's a humax foxsat freesat hd reciever.
    DK Veteran billy2's Avatar
    Jul 2008
    some where over there
    yep it has
    To access the hidden menu for diseqc settings and usals
    Press
    Menu
    Setup
    Freesat tune then press
    Red Button
    Green Button
    Yellow Button
    Blue Button
    Green Button
    Yellow Button
    Blue Button
    Then the Antenna settings option should appear.
    and then you can access the Antenna Settings part of the menu. to set up your diseqc.
    you can pick up all free to air channles and they can be found here
    KingOfSat - European Satellite Zapping & Directory
    V.I.P. Member dctyper's Avatar
    Jun 2008
    how far can this box be used? ie patched or cs?
    Wavefield Ds 55cm at 13E 19E and 28E receiving everything out there on 2 dm800hd
    previous life dm800hd and 500c on cable screw you nag3
    Top Poster Sicilian's Avatar
    Mar 2008
    Quote Originally Posted by dctyper View Post
    This is a non linux box so pretty sure cccam cannot be used, i'm also pretty sure the ethernet port is disabled on these boxes, so that counts out cs.
