Results 1 to 11 of 11
    Feb 2009
    Default Eventually found a TM image with working panel
    Right, after flashing 16+ Technomate images I eventually found one that works on my converted TGC200.
    Like the one Millzzy posted it has working CCcam 2.1.4 and MGcamd 1.35 pre installed and I have them both working.
    It also has a working Panel via Blue button.
    Millzzy mentioned he was having problems with no sound on some TM images but this one works fine for me, not sure how a TGM220 will handle it.
    I was having problems with allot of the TM and EDG Nemesis images in the fact they would not power my Dish or LNB for that matter but this one works fine.
    I've renamed the file to update.img but depending what image your updating from you might need to rename it to TGM220_update.img
    The image was originally named TM9100S_update.img and has a release date of 06/01/11
    Just unrar then ftp the update.img file to your ITgates tmp folder then on your remote control press Menu > Setup > Expert Setup > Software Update > Manual Update > OK > OK
    IMPORTANT: you must do a full factory reset after flashing this image.
    Only use this image if you know what you are doing.
    Worst case scenario IMO would be having to use a null modem cable to serial flash your box to a previous working image.
    Use This File At Your Own Risk
    May 2009
    Eire
    @ deeboi,
    has it a working 7 day epg, if it has ill give it a lash on a tgm220 to see how it goes
    working fine on tgm220...
    Feb 2009
    Unfortunately EPG is still the same as before, now/next on random channels.
    May 2009
    Eire
    there are some epg options in addons via blue button, bit of a pain going to addons to check epg. its working though which is a bonus..nice one deeboi
    Top Poster Millzzy's Avatar
    Nice find deeboi , latest image i found was late 2010 , gonna give this a whirl right now and let u know how it goes ( hopefully sound )
    Confirmed working on TGM220 , Deeboi strikes again ;-) , thanks again mate
    May 2009
    Eire
    im using WeekEPG 3.2b , i know support for these boxes is not there but if you could map a button on RCU that would bring you to channel option in 3.2b then this would be great box that it deserves
    V.I.P. Member haribo's Avatar
    Jun 2008
    in my car
    Quote Originally Posted by stan654 View Post
    you can edit the remote control xml and place in the shared directory
    Used this image today thanks for the image
    Default Technomate Flash
    i bought technomate 500 please give me the steps to flash which enable me to watch sky sports
    V.I.P. Member mdt's Avatar
    Feb 2009
    bolton, north-west. uk
    Quote Originally Posted by mumlareef View Post
    you will need to flash your box with TCC and a null modem lead first with U.R. 31.8.2011 image then search google for the other part of your question as we cant discuss it on here,regards mdt
    DM800HDSE SIM 2.10. SSL84D OPEN-ATV ORBITAL 80CM/DARK MOTOR/IBU/53E-30W
