Page 13 of 29 FirstFirst ... 38910111213141516171823 ... LastLast
Results 181 to 195 of 423
  1. #181
    Aug 2012
    please the pass
  2. #182
    Feb 2012
    Hi all. Has anyone experienced this issue????
    Today when i connected to a FM12 380 i could not access any of the engine ecu tests or parameter programming! I connected a different engine ecu and all was fine! i was able to change chassis id and speed limit no problem!
    With the original ecu it kept giving me the error "10140 wrong answer from control unit" even when trying to perform a compression test!
    Any help with this would be highly appreciated!
    Thanks in advance
  3. #183
    Hello this problem is control unit fault
  4. #184
    Aug 2012
    Can i get user name and password
    ProductGUID=E2F0A8B0-9271-4989-966B-1D44F59EB347
    thanks hope thats my key
  5. #185
    Feb 2012
    Default FM12 Error
    Quote Originally Posted by dieselequipos View Post
    Hi dieselequipos.
    I also had a feeling it was a problem with the ECU.
    What doesnt make sense to me though, is that i could read all the fault codes in the engine ecu but could not access the ecu for any tests or programming.
  6. #186
    PLEASE PASSWORD
  7. #187
    Quote Originally Posted by jsjoe View Post
    Hi dieselequipos.
    yes my friend JSJOe , this problem is on internal ecu its possible the internal memory fault for erase information
  8. #188
  9. #189
    This version PTT1.12 and VCADS Pro 2.40 development, I did not install the GD as it can be done so that the functional currency of menu Tech tool?
    Thank you.
  10. #190
    Senior Member kitty-hawk's Avatar
    FRANCE
    What is the GD ?
  11. #191
    Sorry GD= Guided Diagnostic
    Difference:menu techtool:
    TT1.12 and VCADS Pro 2.40 development : Identification of Vehicle/Machine . VCADS Pro, Impact ,----------- ,Send Support Report , Check for campaigns, Terminology Reference
    TT1.12 and VCADS Pro 2.40 : Identification of Vehicle/Machine . VCADS Pro, Impact, Guided Diagnostics , Send Support Report , Check for campaigns, Terminology Reference
    TT1.12 and VCADS Pro 2.40 development: It is possible in this version programming parameters injectors without buying devtool?
    So far I have not had the opportunity to try. Thank you.
  12. #192
    Dec 2010
    PLEASE PASSWORD
    thank you
  13. #193
    Mar 2011
    Quote Originally Posted by eric486 View Post
    Anyone ever find a fix for this? I am getting the same error message. My laptop has win xp sp3.
    Yes. Manually download MS SQL Server Express and install it first. THen do the original install for PTT>
  14. #194
    Mar 2011
    Does anyone know if PTT will work for off-road equipment?
  15. #195
    Feb 2012
    Default Volvo construction
    Quote Originally Posted by drizzt4321 View Post
    Hi Drizzt4321. With the correct cable it works perfectly!
