usb loader cant find HD - Page 2
Page 2 of 17 FirstFirst 123456712 ... LastLast
Results 16 to 30 of 253
  1. #16
    Junior Member ronnie5's Avatar
    Dec 2011
    Somerset, UK
    Quote Originally Posted by happy_highlander View Post
    no usb loader gx reads from fat32...Is there any games on the hdd and have you updated his wii with the cios pack I linked you too
    Theres about 15 or so games on there and I also installed the cios pack from the link you gave me.
    With the usb loader gx when I select it in the wii menu I dont get as far as the games menu it just goes back to the wii menu and it doesn't say loading sd or loading usb like it does on mine.
  2. #17
    happy_highlander's Avatar
    Aug 2010
    Quote Originally Posted by ronnie5 View Post
    Like I said in the earlier post there is no usb loadergx in the apps folder on the hdd. Ok from the start again extract this file onto a blank sd card Digital Kaos - Downloads - Usbloader gx 2.3 r1128 and d2x v7 with mmm 13.4 (I am always getting you to use a blank sd so that I know what is on it) once you have extracted this file to the sd card put the sd card in the wii and then click the gx forwarder channel and I will bet you it works....If/when it does get back to me and I will go through putting the correct files onto the hdd. Trying it this way first saves a lot of messing about if it doesn't work.
    Edit...I didn't direct you to this file in the first place because I always try to fault find one thing at a time, if I had directed you straight to this we wouldn't have known if the fault lay with cios or the missing file from the apps folder. Sorry if it seems like I was leading you a merry dance, there was a reason for it.
  3. #18
    Dec 2011
    Somerset, UK
    No worries mate!! you know what your doing I dont!! I have downloaded this file but cant do much as the wifes watching soaps!! so I will press on with it probably tomorrow and post back.
    Cheers..
  4. #19
    Aug 2010
    Ok I'm usually about
  5. #20
    Dec 2011
    Somerset, UK
    Well I have done what you said and guess what..... It works!!
    Much appreciated happy_highlander just the job, cant thank you enough!
    Hope this thread helps many others out!!
  6. #21
    Aug 2010
    All you have to do now to make it run without the sd card is to put an apps folder onto the hdd then copy the gx folder from the apps on the sd to new folder on the hdd, this is the reason fat 32 is recommended in modmii as it can be used to store and launch all your apps as well as games, something you can't do with wbfs.
  7. #22
    Mar 2012
    you should ask for a raise!
  8. #23
    Apr 2012
    Thanks guys, I've been search and testing for days, these steps finally helped, so grateful. Sorry for the bump, I just figured this thread could be of use to many who feel lost, like me, Thanks!
  9. #24
    Apr 2012
    Quote Originally Posted by shdwalliance View Post
    what about promotion to CEO (chief entertainment officer) LOL
  10. #25
    Apr 2012
    I'am new, I hope this works for me also..
  11. #26
    Apr 2012
    indiana
    Default USB Loader GX can't find hd
    Happy Highlander, I have been reading this thread and I am having the same issues. I live in the US so I'm not sure if you can help me or not. I used the 43mod hack on my friends wii and the hd can't be detected with the USB loader. If I take the hd and put it on my wii, it works fine so I know it's not the hd. Any help would be greatly appreciated. I ran a sys check and this is what it looks like:
    sysCheck v2.1.0b18 by Double_A and R2-D2199
    ...runs on IOS58 (rev 6176).
    Region: NTSC-U
    System Menu 4.3U (v513)
    Priiloader installed
    Drive date: 2008.07.14
    Homebrew Channel 1.1.0 running on IOS58
    Hollywood v0x21
    Console ID: 82983960
    Boot2 v4
    Found 76 titles.
    Found 55 IOS on this console. 4 of them are stub.
    IOS3 (rev 65280): Stub
    IOS4 (rev 65280): Stub
    IOS9 (rev 54321): Trucha Bug
    IOS10 (rev 768): Stub
    IOS11 (rev 16174): Trucha Bug, NAND Access
    IOS12 (rev 526): No Patches
    IOS13 (rev 1032): No Patches
    IOS14 (rev 1032): No Patches
    IOS15 (rev 1032): No Patches
    IOS16 (rev 54321): Trucha Bug, ES Identify, Flash Access, NAND Access
    IOS17 (rev 1032): No Patches
    IOS20 (rev 16174): Trucha Bug, NAND Access
    IOS21 (rev 1039): No Patches
    IOS22 (rev 1294): No Patches
    IOS28 (rev 1807): No Patches
    IOS30 (rev 16174): Trucha Bug, NAND Access
    IOS31 (rev 3608): No Patches
    IOS33 (rev 3608): No Patches
    IOS34 (rev 3608): No Patches
    IOS35 (rev 3608): No Patches
    IOS36 (rev 54321): Trucha Bug, ES Identify, NAND Access
    IOS37 (rev 5663): No Patches
    IOS38 (rev 4124): No Patches
    IOS40 (rev 16174): Trucha Bug, NAND Access
    IOS41 (rev 3607): No Patches
    IOS43 (rev 3607): No Patches
    IOS45 (rev 3607): No Patches
    IOS46 (rev 3607): No Patches
    IOS48 (rev 4124): No Patches
    IOS50 (rev 14889): Trucha Bug, NAND Access
    IOS51 (rev 4864): Stub
    IOS52 (rev 15661): Trucha Bug, NAND Access
    IOS53 (rev 5663): No Patches
    IOS55 (rev 5663): No Patches
    IOS56 (rev 5662): No Patches
    IOS57 (rev 5919): No Patches
    IOS58 (rev 6176): USB 2.0
    IOS60 (rev 16174): Trucha Bug, NAND Access
    IOS61 (rev 5662): No Patches
    IOS70 (rev 16174): Trucha Bug, NAND Access
    IOS80 (rev 16174): Trucha Bug, NAND Access
    IOS90 (rev 54321): Trucha Bug
    IOS202[57] (rev 65535, Info: hermes-v5.0): Trucha Bug, NAND Access, USB 2.0
    IOS222[38] (rev 65535, Info: hermes-v5.0): Trucha Bug, ES Identify, NAND Access, USB 2.0
    IOS223[37] (rev 65535, Info: hermes-v5.0): Trucha Bug, NAND Access, USB 2.0
    IOS224[57] (rev 65535, Info: hermes-v5.0): Trucha Bug, NAND Access, USB 2.0
    IOS236[36] (rev 65535, Info: rev 3351): Trucha Bug, ES Identify, NAND Access
    IOS245[37] (rev 21007, Info: d2x-v7alpha5): Trucha Bug, NAND Access, USB 2.0
    IOS246[37] (rev 65535, Info: d2x-v3): Trucha Bug, NAND Access, USB 2.0
    IOS247 (rev 65535): Trucha Bug, ES Identify, NAND Access
    IOS248 (rev 65535): Trucha Bug, NAND Access, USB 2.0
    IOS249 (rev 65535): Trucha Bug, NAND Access, USB 2.0
    IOS250 (rev 65535): Trucha Bug, NAND Access, USB 2.0
    IOS251[58] (rev 21007, Info: d2x-v7alpha5): Trucha Bug, NAND Access, USB 2.0
    IOS254 (rev 65281): BootMii
    BC v6
    MIOS v10
    Report generated on 2012/04/23.
    sysCheck #G04CNFBE
  12. #27
    DK Veteran Keithuk's Avatar
    Aug 2010
    England
    Well if that sysCheck is taken off the Wii that doesn't work then
    IOS249 is the default for the USB Loaders you have IOS245 and IOS251 with d2x-v7alpha5, IOS246 with d2x-v3 a bit of a mismatch. Do yourself a favour and install ALL 7 wads in d2x v7.0 Final.
    If you did a sysCheck on the Wii that works with this HDD you will see the differences.
    Keith
    2010 Golf GTD (170)
  13. #28
    Apr 2012
    indiana
    Thanks for the help Keith, I will try it out and reply tomorrow.
  14. #29
    Apr 2012
    indiana
    After installing the d2x v7 files I still can't get the USB loader GX to recognize HD, this is what I have now:
    Region: NTSC-U
    Hollywood v0x21
    Boot2 v4
    Found 76 titles.
    IOS202[57] (rev 65535, Info: hermes-v5.1): Trucha Bug, NAND Access, USB 2.0
    IOS222[38] (rev 65535, Info: hermes-v5.1): Trucha Bug, ES Identify, NAND Access, USB 2.0
    IOS223[37] (rev 65535, Info: hermes-v5.1): Trucha Bug, NAND Access, USB 2.0
    IOS224[57] (rev 65535, Info: hermes-v5.1): Trucha Bug, NAND Access, USB 2.0
    IOS245[37] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
    IOS246[38] (rev 21007, Info: d2x-v7final): Trucha Bug, ES Identify, NAND Access
    IOS247[53] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
    IOS248[55] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
    IOS249[56] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
    IOS250[57] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
    IOS251[58] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
    BC v6
    MIOS v10
    Report generated on 2012/04/24.
    sysCheck #0tCI9pln
  15. #30
    Apr 2012
    indiana
    Keith, this is the sys check from the wii that does work:
    WORKING WII
    ...runs on IOS58 (rev 6175).
    Region: NTSC-U
    Drive date: 2007.02.13
    Homebrew Channel 1.0.8 running on IOS58
    Hollywood v0x11
    Console ID: 72459447
    Boot2 v4
    Found 92 titles.
    Found 46 IOS on this console. 4 of them are stub.
    IOS9 (rev 1034): No Patches
    IOS12 (rev 525): No Patches
    IOS13 (rev 1031): No Patches
    IOS14 (rev 1031): No Patches
    IOS15 (rev 1031): No Patches
    IOS16 (rev 512): Stub
    IOS17 (rev 1031): No Patches
    IOS21 (rev 1038): No Patches
    IOS22 (rev 1293): No Patches
    IOS28 (rev 1806): No Patches
    IOS31 (rev 3607): No Patches
    IOS33 (rev 3607): No Patches
    IOS34 (rev 3607): No Patches
    IOS35 (rev 3607): No Patches
    IOS36 (rev 3607): No Patches
    IOS37 (rev 5662): No Patches
    IOS38 (rev 4123): No Patches
    IOS53 (rev 5662): No Patches
    IOS55 (rev 5662): No Patches
    IOS56 (rev 5661): No Patches
    IOS57 (rev 5918): No Patches
    IOS58 (rev 6175): USB 2.0
    IOS61 (rev 5661): No Patches
    BC v6
    MIOS v10
