jkiad - please edit that sysCheck so we can see it without scrolling down half a bleeding page?
Keith
2010 Golf GTD (170)
Thanks for the downloads, trying to get this to work now!
Ok I'm a bit lost here. Can't get my hd to show up
Got a syscheck, any help would be appreciated.
sysCheck v2.1.0b18 by Double_A and R2-D2199
...runs on IOS58 (rev 6176).
Region: NTSC-U
System Menu 4.3U (v513)
Drive date: 2007.02.13
Homebrew Channel 1.1.0 running on IOS58
Hollywood v0x11
Console ID: 57014983
Boot2 v4
Found 67 titles.
Found 45 IOS on this console. 16 of them are stub.
IOS4 (rev 65280): Stub
IOS9 (rev 1034): No Patches
IOS10 (rev 768): Stub
IOS11 (rev 256): Stub
IOS12 (rev 526): No Patches
IOS13 (rev 1032): No Patches
IOS14 (rev 1032): No Patches
IOS15 (rev 1032): No Patches
IOS16 (rev 512): Stub
IOS17 (rev 1032): No Patches
IOS20 (rev 256): Stub
IOS21 (rev 1039): No Patches
IOS22 (rev 1294): No Patches
IOS28 (rev 1807): No Patches
IOS30 (rev 2816): Stub
IOS31 (rev 3608): No Patches
IOS33 (rev 3608): No Patches
IOS34 (rev 3608): No Patches
IOS35 (rev 3608): No Patches
IOS36 (rev 3608): No Patches
IOS37 (rev 5663): No Patches
IOS38 (rev 4124): No Patches
IOS40 (rev 3072): Stub
IOS41 (rev 3607): No Patches
IOS43 (rev 3607): No Patches
IOS45 (rev 3607): No Patches
IOS46 (rev 3607): No Patches
IOS48 (rev 4124): No Patches
IOS50 (rev 5120): Stub
IOS51 (rev 4864): Stub
IOS52 (rev 5888): Stub
IOS53 (rev 5663): No Patches
IOS55 (rev 5663): No Patches
IOS56 (rev 5662): No Patches
IOS57 (rev 5919): No Patches
IOS58 (rev 6176): USB 2.0
IOS60 (rev 6400): Stub
IOS61 (rev 5662): No Patches
IOS70 (rev 6912): Stub
IOS80 (rev 6944): No Patches
IOS222 (rev 65280): Stub
IOS223 (rev 65280): Stub
IOS249 (rev 65280): Stub
IOS250 (rev 65280): Stub
IOS254 (rev 65281): BootMii
BC v6
MIOS v10
Report generated on 2012/09/10.
All game and usb loader cios are stubbed out. How do you guys manage to keep doing this.....open mmm and select install and patch ios 36 this should install an ios 236. Now go to downloads section and download full cios wad pack. Start mmm reload to ios 236 and install all wads in full pack. If you still don't have ios 236 you can find an ios 236 wad in downloads. Instal it into ios 36 and then follow the above for full pack installation
Welcome to DK Emmet.
I'm not surprised aren't you as thats a sysCheck from a Wii thats only been sofmodded with no additional wads installed.
There area couple of ways to do this download ModMii6.1.5.zip and run Modmii.exe from Windows. Because your Wii is already softmodded you don't need to use Wizard to softmod it. I'm not going to tell you how to use it or what to select as they are all available in here.
What you can do now you have the sysCheck.csv is in ModMii type in SU then the location of the sysCheck.csv file (its easiest to put it on the root of a drive it saves typo's).
That will download all wads and apps in the COPY_TO_SD sub folder to you can just add all these to your SD card, IOS36-64-v3351.wad must be on the root of the SD card. It will also make a web page of the things its downloading with instructions.
Run Homebrew then run IOS236-v5-Mod. After that run Multi-Mod Manager (MMM) and press 'A' to install all wads shown in that list, it defaults to the wad folder on the SD card. On the next screen press 'A' again to install all wads shown, if something it missed press 'B' then scroll down and press + to put a green tick next to the wad then press 'A' again. Install all wads and look for the Installed OK message after each one. If some show and error just install those again.
Now ModMii will install some of the wads it doesn't add the d2x v8.0 final which you can add to the SD card wad folder and install them all with MMM.
After you've installed all those wads do another sysCheck and post the results. All you have to do then is add the USB Loaders that you want to use and install the Forwarder channel so they are on the Wii menu. Then you need to find a suitable mains powered HDD to add your games onto. You need to choose a method of adding these games and the format of that drive, there are plenty of tutorials on here.
Oh I forgot to mention ModMii now adds PriiLoader into the apps folder. Now it only shows hacks_hash.ini in the priiloader folder it may need hacks.ini on the root of the SD card. When you run this from Homebrew if it says hacks.ini is missing download it from PriiLoader 0.7 and add it to the SD card root. In Priiloader you can block online and disc updates and get rid of the 'A' prompt on startup.
Keith
2010 Golf GTD (170)
Hi folks, doing a quick post to get download access. I was having major issues as 3 USB drives were not recognized which i figured was another issue. loaded apps on usb with no sd card in wii and all 3 were recognized. now trying modmii but need cios 249 as mine is stub (whatever that means). I'm a noob and this forum has been the best resource found so far. Thx. I'll try a few things before i post my abject failures.
Welcome to DK.
Now you've made your first post you will have to wait 20 minutes before you can donwload.
The first thing you need to download is sysCheck and add it to your SD card. Run Homebrew and run the sysCheck. After its finished post the a full sysCheck report as instructed in that link.
That will tell use which system your running and which wads you've installed then we can comment on what is missing, and tell you what to download to fix it.
Update:
I tried to make this comment this morning but when I clicked on preview there was a big orange message saying Your account has been suspended.
I clicked on the forum again and that all I saw, I managed to log out and I deleted the cookies in Ccleaner. I clicked on the site again but the big orange message was still there. I checked my emails to see why there was this warning from but nothing showed up from here.
I did a Malwarebytes scan but nothing showed up. I came on the site later with my desktop computer and everything looked ok. I've just come back on with my laptop logged in and its appears to work at the moment.
Keith
2010 Golf GTD (170)
Reposted the syschecd so it should be easier to see . . . Not sure why it is not seeing the USB Hard drive?
Region: NTSC-U
Priiloader installed
Hollywood v0x11
Console ID: 54793903
Boot2 v4
Found 78 titles.
Found 48 IOS on this console. 4 of them are stub.
IOS11 (rev 16174): Trucha Bug NAND Access
IOS20 (rev 16174): Trucha Bug NAND Access
IOS30 (rev 16174): Trucha Bug NAND Access
IOS40 (rev 16174): Trucha Bug NAND Access
IOS50 (rev 16174): Trucha Bug NAND Access
IOS52 (rev 16174): Trucha Bug NAND Access
IOS60 (rev 16174): Trucha Bug NAND Access
IOS70 (rev 16174): Trucha Bug NAND Access
IOS80 (rev 16174): Trucha Bug NAND Access
IOS202[60] (rev 65535 Info: hermesrodries-v6): Trucha Bug NAND Access USB 2.0
IOS222[38] (rev 4 Info: hermes-v4): Trucha Bug ES Identify NAND Access USB 2.0 IOS223[38+37] (rev 4 Info: hermes-v4): Trucha Bug ES Identify NAND Access USB 2.0 IOS224[57] (rev 65535 Info: hermesrodries-v6): Trucha Bug NAND Access USB 2.0
IOS236[36] (rev 65535 Info: rev 3351): Trucha Bug ES Identify NAND Access
IOS249[56] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
IOS250[57] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
BC v6
MIOS v10
Report generated on 2012/09/04.
sysCheck #T6Ps14fv
Syscheck is fine are you remembering there must be a game on the hdd for any usb loader to recognise it
Yes I have about 5 games in the WBTS folder with a fat32 set up. Anything else I need?? I have the USBloader setup as a channel on the wii and it loads fine but when it goes to initialize the Hard drive it says it can not be recognized. I have it plugged into the USB port closest to the edge of the device. Any other insights?
My only other thought is that it is a 3.0 USB drive but it should be backward compatable
You are the second person to have had a problem with a usb 3.0 drive assuming your wbfs folder is on the root of the fat 32 device the setup is correct, is the hdd mains or usb powered as usb powered are not very reliable, one other thing to try is to start the loader then plug the hdd in after the loader says waiting for usb device. I hope that is a typo in your post and your folder is actually called wbfs (lowercase) and not WBTS (uppercase)
Hi. I have just used my SD card to install the homebrew channel on another wii. I downloaded newer software to it (IOS36-64-v3351.wad) and it worked fine - exept for the connection to the hdd...
After almost giving up on the other wii, I put the SD card back into my own wii (including the new wad files), and now my own wii cannot find the hdd.. Up until now I haven't had any connection problems with my own wii...
Any ideas what can have happened?
