usb loader cant find HD
Page 1 of 17 12345611 ... LastLast
Results 1 to 15 of 253
    Junior Member ronnie5's Avatar
    Dec 2011
    Somerset, UK
    Default usb loader cant find HD
    Hello, My boss decided to have a bash at soft modding his 4.3e wii after I told him that I soft modded my kids wii!
    He has gave me his wii to look at as it cant find the hard drive so I installed usb loader gx 2.3 to try and solve the problem but it still cant find the HD, this HD works fine on my kids wii formated to wbfs.
    Is there a WAD file that I should install or something else missing? or anything in the settings that I could change? I have looked through bootmii, priloader and homebrew channel settings but cant find anything to change?
    I dont want to go through the hole softmod process but I may have to?
    Any help would be great!!
    happy_highlander's Avatar
    Aug 2010
    Without a syscheck report we can't tell you if anything is missing as we don't know which softmod method was used. Have you tried installing wiiflow or cfg to see if they recognize the hdd. Did you say your wii recognizes his hdd or is it his wii that recognizes your hdd, try your hdd on his wii
    Dec 2011
    Somerset, UK
    Quote Originally Posted by happy_highlander View Post
    I have no idea how to do a syscheck! The softmod method was modmii. I haven't tried wiiflow or cfg. My wii recognises his HD but I will try my HD on his wii over the weekend when I am off work just trying to get the info ready for weekend so I can crack on with it!
    Aug 2010
    Maybe a silly question but is the hdd being plugged into the correct port. If it is it sounds as though there is a bad cios on there. Modmii is usually very good but as you didn't softmod it you won't know if all wads installed without errors. Take this file Digital Kaos - Downloads - sysCheck v2.1.0 Beta 11 and extract to the apps folder on the sd card run it through hbc and let it check the whole system...This will save a .csv file to the sd card. Put the sd card into the pc then right click the csv file just created and select open with "wordpad" not notepad. Save that file to the pc then copy and paste into this thread and I'll have a look at it and let you know if anything is missing.....Do you know if he has made a nand backup and installed priiloader before you try to make any changes to the system.
    Dec 2011
    Somerset, UK
    Yeah its plugged into the right port! think its port A the outer port but I have tried both. I will download and try syscheck possibly tomorrow eve as the wife is on her night shift! so I will report back once I have done it. He has done a nand backup and has priloader installed.
    Cheers for the help mate!
    DK Veteran Keithuk's Avatar
    Aug 2010
    England
    Quote Originally Posted by ronnie5 View Post
    So he's softmodded and installed PriiLoader and USB Loader GX or he's only softmodded it?
    Does USB Loader GX start up to the main screen or does it say needs cIOS222, cIOS249 or cIOS250 or does do the 20 second count down and say USB Device not found?
    As HH says you need to post a sysCheck report of the bosses Wii, I would also post one of your Wii as well.
    Keith
    2010 Golf GTD (170)
    Dec 2011
    Somerset, UK
    Quote Originally Posted by Keithuk View Post
    He has priiloader installed but I installed usb loader gx which doesnt say it needs any cIOS's just goes back to the main menu.
    Dec 2011
    Somerset, UK
    OK so this is my bosses syscheck
    sysCheck v2.1.0b11 by Double_A and R2-D2199
    ...runs on IOS58 (rev 6176).
    Region: PAL
    System Menu 4.3E (v514)
    Priilaoder installed
    Homebrew Channel 1.0.8 running on IOS58
    Hollywood v0x11
    Console ID: 57041950
    Boot2 v4
    Found 98 titles.
    Found 48 IOS on this console. 4 of them are stub.
    IOS4 (rev 65280): Stub
    IOS9 (rev 1034): No Patches
    IOS10 (rev 768): Stub
    IOS11 (rev 16174): Trucha Bug, NAND Access
    IOS12 (rev 526): No Patches
    IOS13 (rev 1032): No Patches
    IOS14 (rev 1032): No Patches
    IOS15 (rev 1032): No Patches
    IOS16 (rev 512): Stub
    IOS17 (rev 1032): No Patches
    IOS20 (rev 16174): Trucha Bug, NAND Access
    IOS21 (rev 1039): No Patches
    IOS22 (rev 1294): No Patches
    IOS28 (rev 1807): No Patches
    IOS30 (rev 16174): Trucha Bug, NAND Access
    IOS31 (rev 3608): No Patches
    IOS33 (rev 3608): No Patches
    IOS34 (rev 3608): No Patches
    IOS35 (rev 3608): No Patches
    IOS36 (rev 3608): No Patches
    IOS37 (rev 5663): No Patches
    IOS38 (rev 4124): No Patches
    IOS40 (rev 16174): Trucha Bug, NAND Access
    IOS41 (rev 3607): No Patches
    IOS43 (rev 3607): No Patches
    IOS45 (rev 3607): No Patches
    IOS46 (rev 3607): No Patches
    IOS48 (rev 4124): No Patches
    IOS50 (rev 16174): Trucha Bug, NAND Access
    IOS51 (rev 4864): Stub
    IOS52 (rev 16174): Trucha Bug, NAND Access
    IOS53 (rev 5663): No Patches
    IOS55 (rev 5663): No Patches
    IOS56 (rev 5662): No Patches
    IOS57 (rev 5919): No Patches
    IOS58 (rev 6176): USB 2.0
    IOS60 (rev 16174): Trucha Bug, NAND Access
    IOS61 (rev 5662): No Patches
    IOS70 (rev 16174): Trucha Bug, NAND Access
    IOS80 (rev 16174): Trucha Bug, NAND Access
    IOS202[60] (rev 65535, Info: v5.1): Trucha Bug, NAND Access, USB 2.0
    IOS222[38] (rev 4, Info: v0.1): Trucha Bug, ES Identify, NAND Access, USB 2.0
    IOS223[38] (rev 4, Info: v0.1): Trucha Bug, ES Identify, NAND Access, USB 2.0
    IOS224[57] (rev 65535, Info: v5.1): Trucha Bug, NAND Access, USB 2.0
    IOS236[36] (rev 65535, Info: rev 3351): Trucha Bug, ES Identify, NAND Access
    IOS249[56] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
    IOS250[57] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
    IOS254 (rev 65281): BootMii
    BC v6
    MIOS v10
    Report generated on 2012/02/02.
    And this is my syscheck
    Region: PAL
    Hollywood v0x11
    Console ID: 76548340
    Boot2 v4
    Found 108 titles.
    BC v6
    MIOS v10
    Aug 2010
    Both identical and classic modmii so the hdd should work. The only thing this doesn't tell us is if there is a bad cios. It has still installed but may be corrupt. extract this file Digital Kaos - Downloads - Full Cios wad pack onto a blank sd card and put it in the wii then launch mmm through the hbc if it doesn't autoload to ios 236 (it will tell you the current ios at the top of the screen) go down the list till you get to reload another ios (or something similar) then select 236 from the list, then after reload if required go down to wad manager and open it then press "1" on the wiimote this will select all wads and click a "a" to install. This file is all the latest cios for a 4.3 wii including a full set of D2X final they have been confirmed as working. Do not uninstall any cios or ios just let them install straight over the top..
    Dec 2011
    Somerset, UK
    OK I have done that and all the wads installed OK but still not finding the hard drive but I have noticed on the HB channel pressing 1 on the wiimote for options you can select either internal sd slot or usb device this is on option sd slot but when I try to select usb device it highlights it for 2 seconds then un-highlights and does this constantly so I cant select it to stay on, the HD is fine on my wii in the options on HB channel, probably nothing to do with it buts not the same as my wii!
    Dec 2011
    Somerset, UK
    Thinking back to when I started to softmod my wii I think I selected somewhere to use FAT32, NTSC or WBFS to play games from hard drive or something, I cant really remember?
    Dont know if that rings any bells to you?
    Aug 2010
    If your wii recognises the hdd it is formatted correctly. If I try to select usb in hbc with sd card still in it jumps on and off. Remove the sd card and it will automatically select usb to read from. Don't know how you have the sd and hdd setup but the gx forwarder you are using on your bosses wii does not seem to be finding the .dol file for gx to launch try putting an apps folder on an sd with the gx folder in the apps folder then see how you go...One further bit of info I used to have a very tempramental hdd which used to be an internal hdd that I put in a caddy. gx would not recognise this unless i started gx then waited till it said waiting for slow usb device then switch on the hdd
  13. #13
    Aug 2010
    England
    Well I originally use USB Loader GX 2. something and thats the message I got when I tried to run it from HBC without installing cIOS249.
    Those sysCheck's look ok all the correct IOS's are available.
    I read a long time ago thats its better to plug your USB drive in first a wait a minute until it spins up then power the Wii up similar to what HH says.
    Keith
    2010 Golf GTD (170)
  14. #14
    Dec 2011
    Somerset, UK
    I spoke to my boss today and asked him how he went through the softmod process and he said he selected FAT32 to play games via usb as it was recommended and when I done mine I selected WBFS so would it be best to go through the modmii setup again and select WBFS? before I do anything else?
  15. #15
    Aug 2010
    no usb loader gx reads from fat32...Is there any games on the hdd and have you updated his wii with the cios pack I linked you too
