Old INCAL DVD - Page 2
Results 16 to 30 of 41
Thread: Old INCAL DVD
  1. #16
    Open features and settings in Insite. All the info. for the engine is there.
  2. #17
    Top Poster khadang's Avatar
    Jul 2011
    Quote Originally Posted by alsop View Post
    this ecu is not content original calibration. engine run but can't adjust speed, communication j1939 with engine controler error.
    i need reprogram ecu with ogirinal file.
    thank you.
  3. #18
    Please, I hope someone can help me with this calibrations:
    Engine 99N14-525, CPL 2592 for a 3096662 ECM. C10588.01 435HP with 1550lb-ft and C10590.01 with 460HP with 1650lb-ft.
    I have Incal calibrations disks from 2009 to 2012 but there is no calibrations for this ECM under CPL 2592, maybe older disks can help, thanks in advance, best regards.
  4. #19
    Please, anyone have a old set of incal calibrations?
  5. #20
    Please, members can someone help me out with this request.
  6. #21
    Someone has an old 2004 HD Incal disk to share please?
  7. #22
    Aug 2010
    Colombia
    Could someone help me with calibration datafile for cummins ISX N11407.13 , thanks in advance for any help about this...
  8. #23
    I'm still looking for a set of incal disks from around 2003 to 2005, thanks...
  9. #24
    Hi all, I am working on a m11 that wont start, throws code 121 ,replaced eps with three different ones, ohmed out the harness checked for shorts pin to pin, I suspect its the ecm , the only other truck available is a N14, so I would like to flash the m11 ecm to a n14 to see it is good, if it is good then flash it back to the m11. Does any have the files for this thanks!.... N14 S/N11838570 ,cpl2027 ,HP370............... M11 ecm P/N 3096662 eng S/N 34868721 cpl 2037 hp 330... also checked the pin and cam play. Thanks a million
  10. #25
  11. #26
    Jun 2014
    HI
    Im looking incal disc 2 FEB 2012, if anyone got can share with me,
    thanks.
  12. #27
    Hi!
    I am looking for calibration ECM code: J91482 QSC8.3 CASE MX285 or all incal for CNH Case and New Holland
    Thanks in advance.
  13. #28
    Member wrenchead's Avatar
    Nov 2010
    Engine# 8lb001001
    cpl 8519
    isx15
    870
    currently a 475
    looking for highest hp file .
    thank you very much.
  14. #29
    Member ramianek's Avatar
    Aug 2010
    Pleas i need calibration AP90094.02 for ISB E4
    please send me it to PM
  15. #30
    Senior Member colh's Avatar
    April 2010 incal
    incal rar.txt
    pm for pass
  16. The Following 5 Users Say Thank You to colh For This Useful Post:
    bulbox (9th August, 2023), otoy (14th May, 2019), RaceTruck (22nd March, 2017), sova (7th August, 2016), TIGER24 (22nd June, 2019)
