Page 2 of 2 FirstFirst 12
Results 16 to 25 of 25
  1. #16
    levisdj's Avatar
    EcuLand
    What tool did you use to read 95080 or 25080 ?
  2. #17
    levisdj's Avatar
    EcuLand
    And what if I just remove the chip ? will it work to remove immo ?
  3. #18
    Elsewhere
    Quote Originally Posted by levisdj View Post
    Try remove, it depends on the ecu sw version. For me didn`t work without flash, made only virgin and emu, all as original
    It`s not a good solution to remove flash, that flash has some info insinde icluding immo but also other info engine needs them.
    But it`s up to you, if if works with no flash, remove it and you tell us if client content ! ( no AC and servosteering for sure ! )
    Maybe client content without AC and servo, who knows ?
  4. #19
    levisdj's Avatar
    EcuLand
    the idea is, if I remove the chip will it work ? doesn't matter if no ac or power steering.. just wanna see it start. the numbers on the ECU are ****359818 and ****131940
  5. #20
    Elsewhere
    I told you, must try. It depends on the software version ( not written on the case ), older versions work without flash, newer versions no ( because was too simple, everybody could extract the flash and start the engine )
    So you must try, for me none worked without flash, very simple to virgin and i use emu when i cope with those ecus Delphy DCU3R.
    Later edit :
    If you want only see if it start the engine, virgin flash, put it back, cut 20 and the engine will start ONLY THE FIRST TIME !
    You will see if it works, but only once, the second time it will NOT start again ! Protect the flash or emu for alwais starting.
  6. #21
    levisdj's Avatar
    EcuLand
    I removed the chip, now the red light of the immo doesn't turn on.
  7. #22
    Elsewhere
    The immo LED does nothing to do with the ecu ! The immo LED is lit by the UCBIC / UCH.
    You virgin that flash and put it back, see if it goes on. Must start only first time as i said.
  8. #23
    levisdj's Avatar
    EcuLand
    I made a mess, I think I broke the chip.... Now what ?
  9. #24
    Elsewhere
    New chip, ST95080 or AT25080, programmed with the dump ( you have it, don`t you ? ) from the broken one.
    No problem m8, don`t despair !
  10. #25
    Member monir99's Avatar
    Jan 2018
    dz
    regards thanks
