And what if I just remove the chip ? will it work to remove immo ?
Try remove, it depends on the ecu sw version. For me didn`t work without flash, made only virgin and emu, all as original
It`s not a good solution to remove flash, that flash has some info insinde icluding immo but also other info engine needs them.
But it`s up to you, if if works with no flash, remove it and you tell us if client content ! ( no AC and servosteering for sure ! )
Maybe client content without AC and servo, who knows ?
the idea is, if I remove the chip will it work ? doesn't matter if no ac or power steering.. just wanna see it start. the numbers on the ECU are ****359818 and ****131940
I told you, must try. It depends on the software version ( not written on the case ), older versions work without flash, newer versions no ( because was too simple, everybody could extract the flash and start the engine )
So you must try, for me none worked without flash, very simple to virgin and i use emu when i cope with those ecus Delphy DCU3R.
Later edit :
If you want only see if it start the engine, virgin flash, put it back, cut 20 and the engine will start ONLY THE FIRST TIME !
You will see if it works, but only once, the second time it will NOT start again ! Protect the flash or emu for alwais starting.
I removed the chip, now the red light of the immo doesn't turn on.
I made a mess, I think I broke the chip.... Now what ?
