Is there any solution that works, for an immobilizer off??????
Can anyone help me ??
thanks in advance.
The car is;
Renault megane 1900cc
year: 1999
engine: d-F8Q n6
thanks in advance.
The car is;
year: 1999
engine: d-F8Q n6
I think that the immo is in the cut off valve into injection pump. Try to program with renault immo decoder or you must to broke the immo and to suplay it with ACC.
Your ecu is Delphi DCU3R, you can`t do immo off but can be done virgin ! And of course use emu !
You must cut the plastic case to extract the 95080/25080 flash, read it and post dump here to virgin for you.
Cut a square 20x20 mm according to picture :85/65 mm horiz. 20 mm vert. measured from edges.
read eeprom an post it.this ecu can be made immo off.pin 20=immo line and must cut it!
clauberty (16th April, 2013)
hi, thanks.
This is my dump of 25080nc
it can be off,but need to change with 95080 and make write protection
in ecu 25080 (95080)
Your dump virginised.
You cut wire 20 and write protect 25080/95080 ( by the way, 950808 and 25080 are the same thing, but AT25080 is marketing protected name from Atmel, other makers name it 95080 ...ST and so on ...) But easyer with emu.
If mihai_vyt has other opinion, i advise you should do as he says, he`s one of the best !
psyco here is your dump off
sorry for delay
you must write protect eeprom and cut pin 20(immo line)
solution is tested!!
mihai has right ,.you make memory virgin and lock the memory so the ecu cannot write again .
if you make off steering not works.
HI VIRGIN DUMP FOR LUCAS1.9
