Page 3 of 5 FirstFirst 12345 LastLast
Results 31 to 45 of 74
  1. #31
    What about C235C? Is it possible in DAS dvp? And how?
    Thank you.
    Quote Originally Posted by mercis View Post
    only c249f,if it can
    c2498 can you with developer make
  2. #32
    smayer's Avatar
    Jan 2012
    Quote Originally Posted by vwpassat View Post
    Thank you.
    C2498 is service threshold reached. You can solve problem with Das if you unit part number it's not A 005 xxx....
  3. #33
    znoki's Avatar
    Dec 2010
    land of plenty
    Thank you.
    Solution sent in pm.
    even though 2 legs from 8 are not bonded, a spider is a still spider (93c86)
  4. The Following 2 Users Say Thank You to znoki For This Useful Post:
    teamtuner (23rd May, 2017), vwpassat (17th November, 2013)
  5. #34
    workshop
    and i have tested, work 100%
    THX znoki
  6. #35
    znoki's Avatar
    Dec 2010
    land of plenty
    THX znoki
    Cheers Mate!
  7. #36
    DK Veteran ACDC's Avatar
    Feb 2011
    Is it really possible to reset C2498 in dev mode? I even have T-box, to program directly pcb of SBC (used to get rid of C249F before I read that it is possible in DAS dev too :S), but as far as I know C2498 is a no go. If there is a way for getting rid of 2498, please share with me too, as I am very interested
  8. #37
    DK Veteran rappttor's Avatar
    PERPETUUM MOBILE
    I used avdi trying to reset c2498 from a 2002 w211 SBC unit and it doesn't work, so if you have anymore solution please keep me post it.
    Das common procedure dosent work also, tryed many times, c2498 still remains although the usage and time counters become 0. The problem is that this module has a pompe cycles counter wich I cannot reset, and it remains at 123%, das or AVDI same shit
  9. #38
    znoki's Avatar
    Dec 2010
    land of plenty
    Can AVDI read / write the full eeprom file?
    Did anybody try to write a new eeprom file in?
  10. #39
    Europe
    Default sbc
    can any one reset this sbc dump? thx
  11. #40
    Dec 2011
    read your dump and reset it and after you will write it in your sbc modul with avdi tool 100% warrantly
  12. #41
    Europe
    Quote Originally Posted by imoturbo View Post
    was this to me?
    my dump is attached
    i want to reset it
  13. #42
    Jakarta, Indonesia
    Quote Originally Posted by albdiag View Post
    this new dump for your module
  14. #43
    I did a reset on a MY2004 SBC.
    During the test drive I got the red error message and the brake servo gone at 100km/h. Pump motor failed.
    Everyone think about what could happen on the highway without servo brakes.
  15. #44
    Europe
    Quote Originally Posted by bali motor View Post
    i write this dump to the sbc with upa. write and verify ok
    I install back in the car. and faulot was same C2498. I read eeprom via das and eeprom was back as it was originaly
    What is wrong here
  16. #45
    znoki's Avatar
    Dec 2010
    land of plenty
    I guess this dump is more difficult, than just put FF in some lines (checksum, etc)
