Page 1 of 5 12345 LastLast
Results 1 to 15 of 74
    spiridonas's Avatar
    Default MERCEDES W211 SBC C2498 RESET
    Hi guys i have a w211 270cdi and want to remove this fault C2498 from sbc unit .
    I have das developer and i tried to reset the times press the brake pedal.
    I see the first times press is about 500.000 and after reset with this instruction * is 1024 times press, i drive about 20 min the car, but the fault the still exist and i can't erase the fault.
    Please does anyone know how I can erase the fault?
    Many thanks in advance.
    the car is out of warranty
    then 1 line down there you see Bremsenzahler aktualisieren und Lebensdauerzahler F neu berechenen -> click it !
    Parameter uINBR = 0
    then click F3
    1 line down Bremsenzahler auf beliebigen Wert setzen (DJ_SetNBr) -> click it
    Parameter uINBR = 0
    then click F3
    then scroll down untill you see the line's :
    Lebensdauerzahler F neu berechenen (DJ_CalcLiveTime)
    Parameter uINBR = 0
    then click F3
    Lebensdauerzahler F neu berechenen und schreiben (DJ_BuildAndWriteF)
    Parameter uINBR = 0
    then click F3
    Log out of SBC !!
    log out of verhicle !!
    Jan 2012
    Send dump from sbc. I will reset it
    spiridonas's Avatar
    Hi many thanks for you interest my friend.
    How can to read the dump from sbc unit.
    workshop
    no possible this errorcode erase
    They did have a 100k warranty extension on SBC for this fault in the US. Maybe you already know this and this is why you highlited it, but maybe not. There are SBC tools for this.
    AVDI fixes this problem , you can with it read the eeprom by obd2 and then rest the module. Post your dump as told
    Sent from iPhone 4S
    znoki's Avatar
    Dec 2010
    land of plenty
    Did you try to reset this two?
    (DJ_SetLiveTimeNew) uINBR = 0
    (DJ_SetLiveTime) uINBR = 0
    even though 2 legs from 8 are not bonded, a spider is a still spider (93c86)
  8. The Following 2 Users Say Thank You to znoki For This Useful Post:
    Artjom (20th June, 2013), vitamin76 (18th September, 2017)
    Senior Member djamelEZS's Avatar
    SOLUTION IS TO READ DUMP FROM SBC MODULE TO RESSET IT AND AFTER YOU WILL WRITE A RESTED DUMP TO YOUR SBC MODULE TESTED 1000%
  10. #9
    spiridonas's Avatar
    Many thanks guys i can to read the sbc modul only with avdi tool ? or with das developer or other tool?
  11. #10
    znoki's Avatar
    Dec 2010
    land of plenty
    Default EEPROM read in developer mode
    Quote Originally Posted by djamelEZS View Post
    How about "EEPROM" or "EEPROM Upper Page" function in developer mode?
  12. #11
    spiridonas's Avatar
    Yes i can see only the address and byte from dump but i can't read/write i think.
  13. #12
    znoki's Avatar
    Dec 2010
    land of plenty
    You will get different dump if you read by Star Diag, or you read by manually. I don't know how can you convert the dumps, maybe somebody know it?!
  14. #13
    Hi, m8s.
    Anybody can let me know how to read/write eeprom of SBC W211, by DAS devp? Please.
  15. #14
    znoki's Avatar
    Dec 2010
    land of plenty
    By DAS developer you can't write SBC, only read. But the file what you will get, is different what you read physically from the eeprom. The question is, what is the connection between this two files.
    Quote Originally Posted by vwpassat View Post
    Hi, m8s.
  16. #15
    Jul 2012
    Default sbc
