Page 2 of 7 FirstFirst 1234567 LastLast
Results 16 to 30 of 105
  1. #16
    DK Veteran mathura's Avatar
    Aug 2011
    Default FUEL SYSTEM
    UNIT 3: Governors
    Lesson 1: Governors
    Lesson 2: Hydraulic Fuel Ratio Control
    Lesson 3: Sleeve Metering Fuel System
    Lesson 4: New Scroll Fuel System
    Lesson 5: 3406B/C Timing Advance Unit
  2. The Following 18 Users Say Thank You to mathura For This Useful Post:
    1cupdiesel (17th December, 2015), aodfender (25th April, 2016), ckc180 (21st June, 2013), dromeas (15th December, 2017), dupisa (10th September, 2021), hieu1987 (2nd June, 2013), kmno (5th November, 2014), lmtdpq (22nd January, 2014), rimniceanum (7th September, 2013), Roy Suryadwiananda (15th October, 2022), sarjon (14th February, 2019), sfmaldo (23rd February, 2017), sieko (18th January, 2018), t01llam0k (20th January, 2018), tajcenter (30th April, 2013), thangtn (30th December, 2013), toolking (4th January, 2017), Vicus2000 (20th September, 2013)
  3. #17
    Top Poster c16man's Avatar
    Dec 2010
    South Africa
    Thanks for these great stuff mate.
  4. The Following 3 Users Say Thank You to c16man For This Useful Post:
    aodfender (25th April, 2016), Roy Suryadwiananda (15th October, 2022), tajcenter (30th April, 2013)
  5. #18
    Aug 2011
    Default FUEL SYSTEM
    Final Parts of Unit 3- Lesson 4&5
  6. The Following 16 Users Say Thank You to mathura For This Useful Post:
    andhikayudha (20th March, 2017), aodfender (25th April, 2016), ckc180 (21st June, 2013), dromeas (15th December, 2017), dupisa (10th September, 2021), hieu1987 (2nd June, 2013), kmno (5th November, 2014), lmtdpq (22nd January, 2014), rimniceanum (7th September, 2013), Roy Suryadwiananda (15th October, 2022), sarjon (14th February, 2019), sfmaldo (23rd February, 2017), tajcenter (30th April, 2013), thangtn (30th December, 2013), toolking (4th January, 2017), Vicus2000 (20th September, 2013)
  7. #19
    Aug 2011
    Default FUEL SYSTEM
    Sorry I have missed Unit3-Lesson2. Here it is: Lesson 2: Hydraulic Fuel Ratio Control
    EXTRACT
    When the engine is operating with a load, the amount of rack travel in the fuel ON direction is automatically limited by the Air Fuel Ratio Control until the turbocharger speed and inlet manifold pressure is adequate to give complete combustion. This usually occurs by approximately 50% of rated boost and no further restriction occurs. The Air Fuel Ratio Control limits the amount of fuel to the cylinders during an increase of engine speed (acceleration) to reduce exhaust smoke.
  8. The Following 15 Users Say Thank You to mathura For This Useful Post:
    aodfender (25th April, 2016), ckc180 (21st June, 2013), dromeas (15th December, 2017), dupisa (10th September, 2021), hieu1987 (2nd June, 2013), lmtdpq (22nd January, 2014), phasor88 (12th April, 2019), rimniceanum (7th September, 2013), Roy Suryadwiananda (15th October, 2022), sarjon (14th February, 2019), sfmaldo (23rd February, 2017), tajcenter (30th April, 2013), thangtn (30th December, 2013), toolking (4th January, 2017), Vicus2000 (20th September, 2013)
  9. #20
    Aug 2011
    Default FUEL SYSTEM
    UNIT 4: 1.1 and 1.2 Liter Mechanical Unit Injection Systems
    Lesson 1: Introduction to 1.1 and 1.2 MUI Systems
    Lesson 2: MUI Governors
    Lesson 3: Injectors
    Lesson 4: Fuel Settings
    Lesson 5: Fuel Injector Timing
    Introduction
    This lesson introduces the 1.1 and 1.2 MUI system and describes the fuel flow, in addition to the operation of the transfer pump and associated valves. The operation of the governor and various fuel settin adjustments, including the use of the associated tooling, is also covered.
  10. The Following 17 Users Say Thank You to mathura For This Useful Post:
    1cupdiesel (17th December, 2015), andhikayudha (20th March, 2017), aodfender (25th April, 2016), dupisa (10th September, 2021), fredek5 (4th March, 2014), gustpe (29th January, 2015), hieu1987 (2nd June, 2013), kmno (5th November, 2014), lmtdpq (22nd January, 2014), phasor88 (12th April, 2019), rimniceanum (7th September, 2013), Roy Suryadwiananda (15th October, 2022), sarjon (14th February, 2019), sfmaldo (23rd February, 2017), tajcenter (30th April, 2013), toolking (4th January, 2017), Vicus2000 (20th September, 2013)
  11. #21
    Aug 2011
    Default FUEL SYSTEM
    UNIT 5: Introduction to 1.1 and 1.2 HEUI Liter Fuel Systems
    Lesson 1: Introduction to 1.1 and 1.2 HEUI Fuel Systems
    This presentation introduces the 3116/3126 HEUI fuel system. It will
    cover the operation of the fuel system and the mechanical
    components of the engine. We will touch on the HEUI electronics.
    H ydraulically actuated
    Electronically controlled
    Unit
    Injector
  12. The Following 17 Users Say Thank You to mathura For This Useful Post:
    aodfender (25th April, 2016), dromeas (15th December, 2017), dupisa (10th September, 2021), fredek5 (4th March, 2014), hieu1987 (4th July, 2013), kmno (5th November, 2014), lgvanwyk (19th December, 2016), lmtdpq (22nd January, 2014), luiggii79 (6th March, 2016), phasor88 (12th April, 2019), rimniceanum (7th September, 2013), Roy Suryadwiananda (15th October, 2022), sarjon (14th February, 2019), sfmaldo (23rd February, 2017), tajcenter (30th April, 2013), thangtn (30th December, 2013), Vicus2000 (20th September, 2013)
  13. #22
    Aug 2011
    Default FUEL SYSTEM
    Final Lessons
    UNIT 6: EUI Fuel System
    Lesson 1: EUI Fuel System
    UNIT 7: 3054/3056 Nippondenso and Zexel Fuel Systems
    Lesson 1: 3054 and 3056 Fuel Systems
    Lesson 2: Nippondenso and Zexel Systems
    This portion of the course will cover the fuel systems for most of the
    Caterpillar 3054 and 3056 engines. The program will cover the theory of operation for the Stanadyne DB-2 and DB-4 fuel pumps, fuel nozzles, fuel lift pump and fuel filters used on this engine series.
    Table of Contents
  14. The Following 15 Users Say Thank You to mathura For This Useful Post:
    1cupdiesel (17th December, 2015), aodfender (25th April, 2016), arturius (9th March, 2014), dromeas (15th December, 2017), dupisa (25th October, 2018), hieu1987 (4th July, 2013), kmno (5th November, 2014), luiggii79 (6th March, 2016), Roy Suryadwiananda (15th October, 2022), sarjon (14th February, 2019), sfmaldo (23rd February, 2017), tajcenter (30th April, 2013), thangtn (30th December, 2013), toolking (4th January, 2017), Vicus2000 (20th September, 2013)
  15. #23
    Dec 2010
    Portugal
    thank you, friend
  16. The Following 4 Users Say Thank You to Jose Alberto For This Useful Post:
    lmtdpq (22nd January, 2014), phasor88 (12th April, 2019), tajcenter (30th April, 2013), Vicus2000 (20th September, 2013)
  17. #24
    Aug 2011
    Default MACHINE HYDRAULIC SYSTEM
    Overview
    This course is designed to teach the system operations and the testing
    and adjusting procedures for the pilot operated hydraulic system, the load sensing, pressure compensated (LSPC) hydraulic system, the electro-hydraulic system and the hydrostatic system. Students will identify the system components, state the component function and trace the oil flow through the component. Students will also identify the different systems, trace the oil flow through the systems and state the systems operation. When given the appropriate Service Manual and machine, students will conduct the testing and adjusting procedures as stated in the manual.
    UNIT 1
    Lesson 1: Implement Hydraulic System(Pilot Operated System)
    Lesson 2: Steering System (LSPC with Hand Metering Unit
  18. The Following 17 Users Say Thank You to mathura For This Useful Post:
    1cupdiesel (17th December, 2015), aodfender (25th April, 2016), dromeas (15th December, 2017), dupisa (25th October, 2018), hieu1987 (7th December, 2016), kmno (5th November, 2014), lmtdpq (22nd January, 2014), luiggii79 (6th March, 2016), phasor88 (12th April, 2019), phuser (4th January, 2014), rimniceanum (7th September, 2013), Roy Suryadwiananda (15th October, 2022), sarjon (14th February, 2019), sfmaldo (23rd February, 2017), tajcenter (30th April, 2013), toolking (4th January, 2017), Vicus2000 (20th September, 2013)
  19. #25
    Aug 2011
    UNIT 2
    Lesson 1: Electro-Hydraulic Implement System
    Lesson 2: Command Control Steering System
    Introduction
    This unit covers the components nomenclature, functions, locations,
    systems operation, and testing and adjusting procedures for the
    Electro-Hydraulic Implement System and the Command Control
    Steering System.
    The Electro-Hydraulic Implement System is a replacement for the
    Pilot Operated Hydraulic System and the Command Control Steering
    System is a replacement for the Conventional Steering System. Both
    systems are available on the Caterpillar G-Series Medium Wheel
    Loaders.
  20. The Following 15 Users Say Thank You to mathura For This Useful Post:
    1cupdiesel (17th December, 2015), aodfender (25th April, 2016), dromeas (15th December, 2017), dupisa (25th October, 2018), kmno (5th November, 2014), lmtdpq (22nd January, 2014), luiggii79 (6th March, 2016), phuser (4th January, 2014), rimniceanum (7th September, 2013), Roy Suryadwiananda (15th October, 2022), sarjon (14th February, 2019), sfmaldo (23rd February, 2017), tajcenter (30th April, 2013), toolking (4th January, 2017), Vicus2000 (20th September, 2013)
  21. #26
    Aug 2011
    FINAL PARTS
    UNIT 3
    Lesson 1: Basic Hydrostatic Systems
    Lesson 2: Hydrostatic System Controls
    Lesson 3: 950G Wheel Loader Hydrostatic Fan Drive
    System
    Lesson 4: 906 Wheel Loader Hydrostatic Drive System
    Lesson 5: 953/953B and 953C Dual Hydrostatic Drive
    System Comparison
  22. The Following 17 Users Say Thank You to mathura For This Useful Post:
    aodfender (25th April, 2016), chameo (13th December, 2013), dromeas (15th December, 2017), dupisa (25th October, 2018), fredek5 (4th March, 2014), hieu1987 (4th July, 2013), kmno (5th November, 2014), luiggii79 (6th March, 2016), phuser (4th January, 2014), rimniceanum (7th September, 2013), Roy Suryadwiananda (15th October, 2022), sarjon (14th February, 2019), sfmaldo (23rd February, 2017), tajcenter (30th April, 2013), thangtn (30th December, 2013), toolking (4th January, 2017), Vicus2000 (20th September, 2013)
  23. #27
    Aug 2011
    Default ENGINE DIAGNOSTICS & REPAIR
    UNIT 1: Caterpillar Diagnostic Tools
    Lesson 1: Introduction to Diagnostic Tools
    UNIT 2: Engine Oil and Lube Systems
    Lesson 1: Introduction to Engine Oil
    Lesson 2: Caterpillar Engine Lube Systems
    Lesson 3: Special Marking of Crankcase Dipsticks
    Lesson 4: Excessive 0il Consumption
    Lesson 5: Lube System Problems
    Lube System Troubleshooting Lab
    Oils and lube systems quiz
    UNIT 3: Engine Air Induction Systems
    Lesson 1: Introduction to Air Induction Systems
    Lesson 2: Caterpillar Air Induction System
    Lesson 3: Air System Troubleshooting Techniques
    Lesson 4: Temperature Sensing Devices
    Air System Troubleshooting Lab
    Air systems quiz
    UNIT 4: Engine Cooling Systems
    Lesson 1: Introduction to cooling systems
    Lesson 2: Cooling system calculations
    Lesson 3: Cooling system troubleshooting
    : Cooling system troubleshooting lab
    Lesson 4: Cooling system maintenance
    Cooling systems quiz
    Table of
  24. The Following 20 Users Say Thank You to mathura For This Useful Post:
    aodfender (25th April, 2016), arturius (9th March, 2014), dromeas (15th December, 2017), dupisa (10th September, 2021), fredek5 (4th March, 2014), hieu1987 (4th July, 2013), kmno (5th November, 2014), lmtdpq (22nd January, 2014), luiggii79 (6th March, 2016), phasor88 (12th April, 2019), phuser (4th January, 2014), rimniceanum (7th September, 2013), Roy Suryadwiananda (15th October, 2022), sarjon (14th February, 2019), sfmaldo (23rd February, 2017), supergogu (15th November, 2017), t01llam0k (20th January, 2018), tajcenter (30th April, 2013), toolking (4th January, 2017), Vicus2000 (20th September, 2013)
  25. #28
    Aug 2011
    UNIT 5: Engine Fuel Systems
    Lesson 1: Performance curve review
    Lesson 2: Caterpillar fuel systems review
    Lesson 3: Fuel system troubleshooting techniques
    Lesson 4: Fuel related tooling
    Fuel system diagnostics lab
    UNIT 6: Engine Timing and Timing Advance
    Lesson 1: Engine timing and timing advance
  26. The Following 18 Users Say Thank You to mathura For This Useful Post:
    1cupdiesel (17th December, 2015), aodfender (25th April, 2016), dromeas (15th December, 2017), dupisa (10th September, 2021), fredek5 (4th March, 2014), hieu1987 (4th July, 2013), kmno (5th November, 2014), lmtdpq (22nd January, 2014), luiggii79 (6th March, 2016), Lukas roberto (13th December, 2013), phasor88 (12th April, 2019), phuser (4th January, 2014), rimniceanum (7th September, 2013), Roy Suryadwiananda (15th October, 2022), sarjon (14th February, 2019), sfmaldo (23rd February, 2017), supergogu (15th November, 2017), Vicus2000 (20th September, 2013)
  27. #29
    Aug 2011
    Default ENGINE DIAGNOSTICS & REPAIRS
    UNIT 7: Introduction to 3126 and 3176B engines
    Lesson.1: Introduction to 3126B HEUI system
    After learning the information in this presentation, the service technician will be able to:
    1. Identify component locations for 3126 HEUI engines
    2. Identify electronic components for new electronics package
    3. Identify new features on 3126 HEUI
    4. Understand fuel system operation on 3126 HEUI
    5. Understand differences between 3100 MUI and HEUI
    Lesson 2: 3126B HEUI engine
    1. Identify component locations for 3126B engines
    2. Identify new features on 3126B engines
    3. Understand the operation of the 3126B engines
    4. Understand differences between 3126B engines and the 3116/3126 engines
    Lesson 3: Introduction to 3176B engine
    1. Locate and identify changes madeto 3176B engine components
  28. The Following 23 Users Say Thank You to mathura For This Useful Post:
    1cupdiesel (17th December, 2015), aodfender (25th April, 2016), arturius (9th March, 2014), dromeas (15th December, 2017), dupisa (10th September, 2021), fredek5 (4th March, 2014), hieu1987 (4th July, 2013), kmno (5th November, 2014), lmtdpq (22nd January, 2014), luiggii79 (6th March, 2016), mecanico (1st February, 2023), phasor88 (12th April, 2019), phuser (4th January, 2014), rimniceanum (7th September, 2013), Roy Suryadwiananda (15th October, 2022), sarjon (14th February, 2019), sfmaldo (23rd February, 2017), supergogu (15th November, 2017), tajcenter (30th April, 2013), thangtn (30th December, 2013), tijs (14th August, 2022), toolking (4th January, 2017), Vicus2000 (20th September, 2013)
  29. #30
    Aug 2011
    FINAL LESSON
    UNIT 8: Introduction to Electronic Engine Diagnostics
    Lesson 1: Introduction to electronic engine diagnostics
  30. The Following 17 Users Say Thank You to mathura For This Useful Post:
    1cupdiesel (17th December, 2015), aodfender (25th April, 2016), dromeas (15th December, 2017), dupisa (25th October, 2018), fredek5 (4th March, 2014), hieu1987 (4th July, 2013), lmtdpq (22nd January, 2014), luiggii79 (6th March, 2016), phuser (4th January, 2014), rimniceanum (7th September, 2013), Roy Suryadwiananda (15th October, 2022), sarjon (14th February, 2019), sfmaldo (23rd February, 2017), supergogu (15th November, 2017), tajcenter (30th April, 2013), thangtn (30th December, 2013), toolking (4th January, 2017)
