Page 2 of 2 FirstFirst 12
Results 16 to 30 of 30
  1. #16
    May 2011
    on the road
    Maybe problem from BDM software
    I read and write ME 9 from BMW, with Magpro2 BDM v3
    and no problem.
    No need external power
    best regards
  2. #17
    Jan 2013
    Can you share this thread ,,Found a thread where it says to short some parts in the circuit board of the ME9.2 to enable write'',because i got the same problem.Thanks in advance
  3. #18
    Azzx's Avatar
    Sep 2011
    South Poland
    EPEE need to be activated in case of delete/write - no problem after that.
    Tested, works like a charm.
    We choose to go to the moon.
    What would be life without a risk?
  4. The Following 11 Users Say Thank You to Azzx For This Useful Post:
    adiagnostyka (4th December, 2018), AlexisN (23rd May, 2019), brobble (30th March, 2016), foxibg (29th February, 2016), lechus111 (21st March, 2019), marcin7091 (8th September, 2018), motocarlos (28th October, 2018), pawliukazz (9th May, 2014), prusony (26th June, 2022), sasa5 (18th May, 2016), toniz (24th October, 2013)
  5. #19
    Jan 2013
    I should remove them from the computer?Thanks in advance
  6. #20
    Azzx's Avatar
    Sep 2011
    South Poland
    Yes you must remove the resistor during the whole procedure.
  7. #21
    May 2012
    Hi, I have the same problem and cannot write this flash.I will try your it. Tell me please short I must do from left or right side place resistor?
  8. #22
    May 2012
    Quote Originally Posted by Azzx View Post
  9. #23
    May 2012
    ALL WORKING!!!!!!!!!!!!! THANK YOU VERY MUCH!!!!!!!!!!!!
  10. #24
    Azzx's Avatar
    Sep 2011
    South Poland
    Glad you sort it out
  11. #25
    May 2016
    I need help with this also. I can't activate epee. What resistor need to be removed?
    Sent from my SM-G530T1 using Tapatalk
  12. #26
    Aug 2014
    Can anyone share picture to what i have to do?
  13. #27
    motocarlos's Avatar
    Jun 2009
    porto, portugal
    I have same prloblem with edc 16U1 VW Touran, does this solution "short" was good to that ecu too?
    Regards.
    WORK WITH KWP 2000+, GALLETO 1260, BDM 100, FLASTEC CLONE WITH MAGPRO2, VAGCOM, FIAT ECUSCAN,UPA USB, MAXIDIAG, TOP 2049, PROG EXPRESS, AND MORE....
  14. #28
    Dobermann's Avatar
    Germany
    Hello Tuner Friends !
    I know this is an old Thread but i think in Future somoen can use this information.
    i had the same problem with write error BDM100 on Bosch DME7 (ME9.2) with 28F800F3 chip.
    The last bytes can not be written. Its only possible if WP is dissabled.
    the solution is to solder a wire on Pin 53 (28F800F3T) to 3,3V and WP is dissabled.
    if you are using a 10 Pin Adapter like me than you can solder the wire on the first Pin on the left side (3,3V) - Look at the Picture
    The DME7 have only 12 Pads not 14 like in other Bosch Ecus (edc16)
    i do this post only because i haven't found a really good explanation how to.
    i hope i can help with this post some people with the same problem !
    best regards
    KESS3, KESS V2 and KTAG Original , ECM Titanium Genuine, CarProg V13.19, Flex Full
  15. The Following 2 Users Say Thank You to Dobermann For This Useful Post:
    eclipse31 (25th November, 2023), prusony (26th June, 2022)
  16. #29
    Apr 2023
    Belgorod, Russia
    Lightbulb
    Hello to all!
    As a result of experiments, I found a more convenient way to activate the recording - just close 2 contacts and that's it! Tested personally.
  17. #30
    dimitar's Avatar
    When using galleto or ktag dont need any modifications
    I also had problems cloning this ecu with bdm100 and xprog
    50w Soldering Iron
    Chisel
    Sometimes Hammer
