Vu+ Duo Clone *3.1.1 Kernel Update* - Page 2
Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 48
  1. #16
    Mar 2011
    Anyone tried the latest VIX image with this update? Any problems with it on the clone box?
  2. #17
    digicon's Avatar
    Default Vu+ Duo Clone *3.1.1 Kernel Update* Revision 3
    Just an Update Ferrari have in the last 2 days released 2 new versions of this update the one i have posted here is the latest Revision 3, The only difference is this one will let you go back to older images if you prefer, There is nothing wrong with the other files so no need to be alarmed that is the only change with this loader
  3. #18
    Newbie garry002's Avatar
    Jan 2009
    it must be done before or after the flashing image? once or every time of flash new image?
    Israel, Afula. Ukraine, Kiev
    Sorry for my english.
  4. #19
    digicon's Avatar
    Quote Originally Posted by garry002 View Post
    Just the once before you upgrade the image once done that's it.
  5. #20
    Feb 2012
    Default Vu+ Duo
    I have just taken delivery of a Vu+ Duo.
    Any tips, tricks and the best way of getting this unit up and running would be appreciated.
  6. #21
    DK Veteran potrobber's Avatar
    N Ireland
    Quote Originally Posted by colin445 View Post
    is this a clone or genuine unit?
    first thing you need to do is download the image you want to go with and put it on a clean usb stick
  7. #22
    V.I.P. Member mdt's Avatar
    Feb 2009
    bolton, north-west. uk
    firstly you should say hello in the introductions thread then update your signature and profile with your system(dish size,fixed or motorised) and state if your box is a original or clone. give as much info as possible... help us to help you!!, regards mdt
    DM800HDSE SIM 2.10. SSL84D OPEN-ATV ORBITAL 80CM/DARK MOTOR/IBU/53E-30W
  8. #23
    Jan 2009
    I have a problem with the duo clone. He does not running, the display is written "starting" and then to "vu+ duo" and starting again. What can I do?
  9. #24
    V.I.P. Member dell_xps's Avatar
    You'll have to reinstall the image m8, update the kernal first then install the latest image.
    Look for Digicons post about clone kernal ok.
  10. #25
    Jan 2009
    what is the "image m8"?
  11. #26
    Sep 2010
    Quote Originally Posted by dell_xps View Post
    You'll have to reinstall the image m8, update the kernal first then install the latest clone image.
    Look for Digicons post about clone kernal and clone firmware, do not use official firmware from Vix etc. use modified Vix etc firmware or you will brick your clone ok.
    i'm sorry mate but thats wrong. there are no "modified" images as there are no so called clone bombs. you have to patch the receiver it self so that it can run kernel 3.1.1 images.
  12. #27
    I stand corrected RD !
  13. #28
    Apr 2012
    Hi, i try to update a MAX+Solo (Vu+solo clone) but 1? step update don't start...
  14. #29
    Does it have a white v2 sticker on top of it ?
  15. #30
    V.I.P. Member benny/9's Avatar
    Nov 2008
    north west uk
    here is the duo_scret 311 kernal update file
    along with the loader panel to send it to your box
    dont forget to use the rs232 board in line with your
    null modem cable when loading this file
    Please Read Carefully!
    No Sky UK NDS Videoguard Hacking Discussions.
    Viewing Pay TV without a valid subscription is illegal
    the files available are kept for experimental & educational purpose only
    original vu duo2 /vu zero/ tm-nano-se. v-box / 36v /1.2 dish,
  16. The Following User Says Thank You to benny/9 For This Useful Post:
    hassanko (27th November, 2013)
