Vu+ Duo Clone *3.1.1 Kernel Update* - Page 3
Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 48
  1. #31
    digicon's Avatar
    Quote Originally Posted by benny/9 View Post
    here is the duo_scret 311 kernal update file
    along with the loader panel to send it to your box
    dont forget to use the rs232 board in line with your
    null modem cable when loading this file
    A search is all that's required
    Kernel Update
  2. #32
    Jun 2012
    How I can unbrick Max+ solo clone?
    Thank you!
  3. #33
    Jul 2012
    I did it, bricked my vu+ duo clone by using the solo bootloader. Darn...
    Is there already a way to fix this?
  4. #34
    V.I.P. Member benny/9's Avatar
    Nov 2008
    north west uk
    Quote Originally Posted by geba View Post
    this is posted on the ferrari forum to fix your box
    take a look at the pfd attachment then take a look
    and ask on that forum
    Please Read Carefully!
    No Sky UK NDS Videoguard Hacking Discussions.
    Viewing Pay TV without a valid subscription is illegal
    the files available are kept for experimental & educational purpose only
    original vu duo2 /vu zero/ tm-nano-se. v-box / 36v /1.2 dish,
  5. #35
    Jul 2012
    Gonna try that. Thank you!
  6. #36
    Jul 2012
    thank you lot
  7. #37
    Jul 2012
    Default big problem vu+solo
    Good morning to all I ask for help for my vu + clone had only 166 image I discovered later that it was a clone, but now I had purchased I updated the kernel to 3.1.1 then 1.7.6 then also the image but no 1.7 .5 1.7.4 1.7.3 1.7.2 and still nothing does not work now even with the 1.6.6 what should I do? please help thanks
    1 -installing the soloboot.bin with UpdateAllFlash.exe
    2 -installing the UPFLASH120227.bin with renewflash.exe
    3 -Erase the memory with ERASE126.exe
    4 -installing the Secret SOLO-120229.bin with secupd111230.exe
    5 -installing the cfe_solo_2.0 with a usb pen drive
    6 -installing a image XX with the usb pen drive
    but nothing help me please
  8. #38
    DOUGALMCD's Avatar
    May 2011
    Suburbia
    If it's solo post in the solo section and welcome to Digital Kaos.
  9. #39
    Aug 2012
    please let me download this
  10. #40
    Jun 2008
    when i try tot do "VU DUO secret chip update 120229" with null modem kabel en board, receiver starts, and display shows "Starting"....
    afther 5 min, still the same
    i just instaled BH 1.7.3 whitour problems
    do i still need update?
    regards,
  11. #41
    Feb 2012
    If your vu+ duo clone has a v2 sticker on the back it's already been done. Does it have this sticker?
  12. #42
    Jun 2008
    thanks for reply
    no it has no v2.0 sticker
    i manage to update on other pc with integrated com port.
    with usb2com adapter not worked on my (this) pc
    regards
  13. #43
    DOUGALMCD's Avatar
    May 2011
    Suburbia
    As digicon gives you ic update on post 1 you seem to have done this but he also gives you bootloader on post 31 which it seems you have not done. So if you have clone v1.......
    1 ic update via board and null modem cable
    2 format usb unzip bootloader [make sure you have correct one for your box] put on usb then flash this takes seconds.
    3 format usb again load image to usb [Again correct one for your box if your not sure ask] then flash do not pull out usb until done once finished reboot.
    If you read the whole thread you may get there. Any info is for help only fiddle about at your own risk.
  14. #44
    Default Question On VU + Clone
    As the title has been released today and is fully working on new Images using Kernel 3.1.1 and latest drivers
    Tested myself Currently Running Blackhole 1.7.2 Media Tree
    I have enclosed both the software and Readme file, Please read before you do the update.
    Thanks to the Guys at Ferrari Forum
    Hi recently bought a clone vu+ duo box and its currently running Blackhole 1.7.2 Media Tree. is it safe to assume that this is using the new kernel update . I was looking to flash BH 1.7.5 any would be help gratefully appreciated
    Dan
    Kind Regards
    Dan
    Last edited by satmandanuk; 31st August, 2012 at 12:46 PM. Reason: bad spelling :-(
  15. #45
    DOUGALMCD's Avatar
    May 2011
    Suburbia
    This has 3.1.1 kernel.
    Good idea to make a full back up before you flash.
  16. The Following User Says Thank You to DOUGALMCD For This Useful Post:
    menaco (22nd May, 2014)
