VU+ UNO / DUO CLONE QUESTIONS & ANSWERS ONLY. - Page 2
Page 2 of 13 FirstFirst 123456712 ... LastLast
Results 16 to 30 of 185
  1. #16
    digicon's Avatar
    Quote Originally Posted by mickmc68 View Post
    Hi all is there any other way to flash the kernal on a duo clone without using the 232 board and null lead ? as ive used various leads , comps running xp and win7 and i still cant get the file to flash
    Mick
    Sorry to say this mate 'NO' it has to be done via the null lead and the IC chip
  2. #17
    Belfast
    Thanks for the reply m8 , do u know how i would find out wat is at fault eg the 232 board ect ?
    or could u recommend an easy to work with image to use
    Mick
  3. #18
    digicon's Avatar
    Mick
    Hi Mick,
    If you cant flash the latest loader which is basically the new linux kernel 3.1.1 the you can still use any image prior to Dec 2011, all the loader does is lets you use the latest images and also revert back to the old ones.
  4. #19
    V.I.P. Member dell_xps's Avatar
    PM Digicon if he doesnt reply, he has a clone and knows how it works m8.
    EDIT, MUST OF REPLIED JUST AS I WAS WRITING THIS :-)
  5. #20
    Belfast
    Thanks im just trying to BlackHole 1,6,6 image now
    Mick
  6. #21
    V.I.P. Member mdt's Avatar
    Feb 2009
    bolton, north-west. uk
    cant you get onto the supplier to send you a new IC board?? regards mdt
    DM800HDSE SIM 2.10. SSL84D OPEN-ATV ORBITAL 80CM/DARK MOTOR/IBU/53E-30W
  7. #22
    Belfast
    Hi m8 i was offered the loan of 1 to see if thats the prob , im just waiting on it comming
    Mick
  8. #23
    Sep 2008
    you mentioned a null modem cable ?? is it when people get kryptview cable boxes they may get a serial cable which is wired straight and therefore cannot flash boxes,null modem cable has a crossover wire for flashing.
  9. #24
    Belfast
    hi m8 ive used the lead and 1c board that came with box and also a few null modem leads ive hanging abt from KVs ect still no joy
    Mick
  10. #25
    DK Veteran andy211081's Avatar
    May 2009
    Doncaster
    i have 2 original VU Duo boxes but im bored and wanted to mess about so bought a clone to mess about with. was ?172 so will see what its like...no doubt i will **** it up on first attempt
    Ladies and Gentlemen, this is your captain speaking. I have the only gun on board. Welcome to Con Air.
  11. #26
    DK Veteran Rodbouy's Avatar
    I ordered my mate one from Tina,.
    After have used a original duo, the clone is by first impressions a good alternative.
    Flashed no problem with bh 1.6.6 as i feel its the best ver of the bh series.
    The fan is slighty more noisy than the original but not a deal breaker.
    Remote just the same.
    Overall for ?175 you can't go wrong, well you can but you get what I mean.
  12. #27
    digicon's Avatar
    If the Fan is noisy then there is something wrong with it, Mine is whisper quiet it may require reseating
    Quote Originally Posted by Rodbouy View Post
  13. #28
    You might be right, I will check it out before I give him it.
  14. #29
    Jan 2011
    Default vu solo
    ive just got a vu+solo clone but im having problems at the moment as im having to turn it off at socket all the time when im flicking through channels it will go to so many channels then it will fail on some like sky sports or movies untill i turn the box off at the wall then it will be ok for a bit its doing my nut in where i bought the box from they sent me some files for installing the new software which is how to update the security ic for duo and solo but from wat ive read on the instructions i think theres a file missing as it wont update
  15. #30
    Jan 2011
    Default vu solo
    now on that i cant find the file aesencode.bin this is the files i got from them
