VU+ UNO / DUO CLONE QUESTIONS & ANSWERS ONLY.
Page 1 of 13 12345611 ... LastLast
Results 1 to 15 of 185
    V.I.P. Member dell_xps's Avatar
    Default VU+ UNO / DUO CLONE QUESTIONS & ANSWERS ONLY.
    Only for Vu+ Uno / Duo clones & Solo's, all original receivers please use other threads.
    Nov 2011
    What about solo's.
    digicon's Avatar
    Quote Originally Posted by den169 View Post
    What about solo's.
    I cant see why not seeing as the Uno Clone has yet to surface and an Ultimo clone is in the works also.
    Updated guys !
    Nov 2011
    Backed up the vu+ solo VIX 2.3 with VUCC then rearranged my local channels on SGT flipflops epg with dreamboxedit, All ok but now when i try to use VUCC or dreamboxedit they just don't respond they can't seem to connect to the box now no big deal till the next time i want to update all the channels as everything is working as it should at the moment.Also tried an older pc with windows xp on still the same anyone got any ideas how to sort this last time it did this i finished up reinstalling vix 2.3 and everything else this is a clone.
    Cheers
    Does the clone not show up in your network m8 ?
    Original shows up I can transfer files etc etc, and if I use the web browser I can stream TV etc
    V.I.P. Member mdt's Avatar
    Feb 2009
    bolton, north-west. uk
    Default solo clone
    ive just took delivery today of a solo clone and im looking to use a usb/wi-fi stick to connect to my network... can anyone recommend a reliable cheap one? i have a spare set of homeplugs but i was looking to give wi-fi a go if possible. regards mdt
    DM800HDSE SIM 2.10. SSL84D OPEN-ATV ORBITAL 80CM/DARK MOTOR/IBU/53E-30W
    Vonnets wifi bridge works m8, ?20 on Ebay, probably best to use a power supply with it though.
    Nov 2011
    Quote Originally Posted by dell_xps View Post
    It did till i tried to change some channels in dreamboxedit a second time now it doesn't can't get it through a web page iether.Must be something in the box.
    Has it changed ip address m8, go into network settings and check what ip address it's using, also check it's using port 0080 for yer web tv :-)
    Feb 2009
    i have 2 of those but i thought they were for use with a dm. so if i use a vonets wi-fi bridge and power it with a dm800/dm500 psu then it should be ok? regards mdt
    Nov 2011
    Thats the problem Dell thanks for that.I am a newbie at this.
  13. #13
    I used it on my Duo for a few days MDT, but prefer the home plugs TBH, as long as it's get power from another source should be ok ?, I wouldn't just plug it into a usb socket m8, better to have an external supply going to it.
  14. #14
    I'm still a newbie to m8, you can only learn something if someone informs you how it works etc, simples :-)
  15. #15
    Belfast
    Hi all is there any other way to flash the kernal on a duo clone without using the 232 board and null lead ? as ive used various leads , comps running xp and win7 and i still cant get the file to flash
    Mick
