VU+ UNO / DUO CLONE FIRMWARE ONLY.
Page 1 of 3 123 LastLast
Results 1 to 15 of 38
    V.I.P. Member dell_xps's Avatar
    Default VU+ UNO / DUO CLONE FIRMWARE ONLY.
    ONLY PUT CLONE FIRMWARE IN HERE FOR THE VU+ UNO / DUO, THANK YOU.
    good place to start is this thread, all credit to Digicon !!
    http://www.digital-kaos.co.uk/forums...update-255713/
    Sep 2010
    Technically there is no such thing as clone firmware for any Vu receiver, its all original. The only differences being the kernel version and drivers. Its not like a DMM where the bootloader and drivers are specifically patched.
    once you load the latest security IC patch to the box you just load a the image of your choice.
    satsmo's Avatar
    Jun 2008
    I know and I am only following what the voters have said, by creating stickies from dell's latest posts
    But that's what I have been trying to say all along.
    I refuse to answer that question on the grounds that I don't know the answer. - Douglas Adams
    Sep 2010
    I know mate, it just gives users a false sense of security to see images labeled as clone images when in actuality they are not. especially now that Ferrari have released their new patch for the cloned boxes.
    Some people will buy a clone thinking it's a genuine receiver, without doing much reading they'll dive in and install the latest image on there cloned box, making it an expensive brick.
    Yes I know some people are aware there buying a clone, so really this is for people who have just started out, we all started knowing nothing !!
    RD I know you are against clones, but as above, some people will think they are buying the genuine box.
    Senior Member zee24's Avatar
    Jan 2011
    Once a box is bricked is there anyway way to resurect it?
    Not 100% sure m8, don't think there is a jtag or that out at the moment, but I could be well wrong.
    Sep 2010
    Quote Originally Posted by dell_xps View Post
    There are a few inconsistencies with that statement.
    1. if you load a kernel 3.1.1 image to a cloned receiver it simply will not boot until you reload with a earlier version image or you flash the box with the IC security update and load the image again. It will not brick the box.
    2. and i have said this many many times. I am not against clones providing those people know what there getting them selves into. and frankly i'm getting fed up to the point of actively staying away from the forum / helping in posts because of people making these assumptions about me all the time. Those who have read my posts know my stance.
    my point here was to clear up for newer less knowledgeable members that may see a image labeled as a clone image. as i said there are no clone images as the images them selves are not patched or touched in any way, all the patching goes on in the receiver it self. i am just making people aware of this after all why make a cloned box section if not to educate people about clones and how they work ?.
    Sep 2010
    Quote Originally Posted by zee24 View Post
    That depends on how you define bricked.
    if you flash a 3.1.1 kernel image to a unpatched clone receiver the worst that will happen is the box wont be able to boot with this kernel until you reload a earlier version image.
    The only way to properly brick a clone or original Vu for that matter is to botch the bootloader update or as some people on the Ferrari forum have by loading the bootloader for the wrong box to their receiver. This always ends in a receiver that at present can not be repaired clone or original.
    Did someone not brick there Duo a while back by installing the Uno / Solo firmware on it ?, might be totally wrong.
    Sep 2010
    obviously loading the firmware for the wrong box is not a good idea same as it would be for a dreambox.
    DK Veteran freck's Avatar
    Jul 2008
    Dark side of the Moon
    Dont think that the VU+Uno is cloned Dell???
    VU Solo you mean yeah?
    Freck
  13. #13
    Yup, mod will have to change header m8 :-)
  14. #14
    digicon's Avatar
    Default Vu+ Clone Duo & Solo *Stuck Red Light Boot Fix*
    Please find below for download, I am assuming this is a fix if you brick your box. Bin files enclosed for both Duo & Solo so please read the enclosed Flashing instructions before attempting this procedure.
    Thanks again to Ferraricard on Ferrari Forums
  15. The Following 2 Users Say Thank You to digicon For This Useful Post:
    adam1w (26th August, 2020), unob (28th October, 2014)
  16. #15
    May 2012
    Tell, please, from what system to update firmware clone Vu+duo, Windows 7 or XP better?
