Page 5 of 13 FirstFirst 12345678910 ... LastLast
Results 61 to 75 of 193
  1. #61
    Oct 2012
    Default hello
    i have just finished my install,but i have some channel\satellite problems.
    i have a strong signal on 19.2e but i can only get one channel, and the box only displays sky uk in the sat list.
    any one able to help?
    oh by the way i'm completely new to anything sat related.
  2. #62
    Apr 2011
    hi shady,i have got a skybox f3 with gift,when the gift runs out where do i buy a new one,thanks in advance
  3. #63
    Nov 2012
    Quote Originally Posted by Shady View Post
    Little guide i made
    Hopefully be of some use
    https://skydrive.live.com/redir.aspx...124&parid=root
    HI
    WILL THIS WILL WORK ON A SKYBOX M3 BEFORE I TRY IT?
    MANY THANKS
  4. #64
    Nov 2012
    Hi Shady,
    It says that you can get the
    Channel list & Image file on this website
    I got Aj's channel list but can't find the image file(.abs) anywhere.
    Can you help with this?
    Just incase anybody else has this question the skyboxf3 comes with the image already so miss the image part out on the guide.
    PMD you back Deffo
  5. #65
    Nov 2012
    Quote Originally Posted by pirateone View Post
    hi guys im new to all this and im looking for for new channel listings. thanks a bunch
    I was told this one is good mate
    http://www.digital-kaos.co.uk/forums...ularly-260273/
  6. #66
    Nov 2012
    Default Just ordered an X3 so I'm posting so I can start downloading ;^)
    Also I#m a linux programmer by trade - are there any people developing firmware downloads for the X3? I'd like to join in...
  7. #67
    Nov 2012
    Question image file (abs)
    i hav got the channal list but i am trying to find the image file as i cannot find it anywhere so could u pls help me with this also i am very new at at this
  8. #68
    Nov 2012
    Ive stopped being thick now and managed to get a line up and running, mu only issue now is that ive installed that scooby snacks on the box so the only satellite it shows is Sky 28.2E. when i scan i dont get a full list of channels, i get loads of ITV and Channel 4 ect.... Nickelodeon and a few others but no sky 1 Films and appears the sports channels have codes ie 34102 instead of Sky Sports 1
    I tried adding that AJs list but when i go on the channels there is says no signal. I know the line is working??
    Im on a Skybox F3 if anybody has any ideas?
  9. #69
    Nov 2012
    Default Network S9 setup
    I follow the set up and imput all info but no TV.
    in the Network Setup...I connetcted the ethernet cable ,turned DHCP to OFF and ON...Apply.
    NEWCam Server Setup: Newcam server Parameter..Server setting ' on',TCP port ' 10410 ' and dthe DES Keys 'xxxxx28 timexs' ..these are the keys it was from the Private Server.
    Newcam Serv User Manager ' enter user and P/W.
    In the CCcam Client Setup ' Manage Conf files ' ' CCcam.cfg'
    Enterred the Server Private info ' IP,User,P/W and port,Des keys ' press the Green button (Active ) ...still No tv
    Any help
    Tnx
  10. #70
    Dec 2012
    Hi all,
    I have installed WATCH in OPENBOX S10! this method:
    menu - information - on the remote control button - red - green - yellow - blue - and hit 8 and a hard reboot.
    The question is how to undo?
  11. #71
    Dec 2012
    Smile Newbie
    Just got sky box m3 loaded the channel list files , not getting all the channels ,Does the channel change everyday ?
    pls help
  12. #72
    Default cline set up
    hi m8 thanks for the reply on the tutorial were it says cline set up it says if you have not got a cccam.cfg file jump to 27 were is 27 m8 also if you could help were do i get a cline from thanks .
  13. #73
    Dec 2012
    you cant get sealion on here, google something like f3 gift or something like that and you will find.
    a question i have though is.. my sealion is 3 lines long from my seller... do i just put it all in one document in notepad, or create three notepad files??
    cheers.
  14. #74
    Shite Link King Shady's Avatar
    Dec 2010
    192.168.1.xxx
    all in one notepad.
    and kvethered, its an editing mistake.. jump to number 9
  15. #75
    Dec 2012
    Hi am new to this forum and have purchased an openbox s11. how do i go about this. If any body can help
