u should read flash 29F400
Hi all,
I have one car, peugeot 406 , 2001, 2.0 L benzin
IAW 48P.11 25c080 and 29F200 inside
Customer lost his keys and want's IMMO off.
He has SIEMENS BSI.
I only read 25c080 ... Do i need to read 29F200 aswell or it can be don only by EEPROM ?
Thank You
Dosen't matter how hard is to repair something as long is made by humans and thinked by humans !
it is 29F200... this will not work only with eeprom 25C080 ?
Thank you
You must read flash is only way to do.
Dane
after i read flash, make it IMMO off, do i need to program 25c080 aswell? or do i need to cut some ECU pin ? if i need to cut a wire, you can tell me which one is it? or do i need to take out immo box? located on the ignition lock?
thank you i will read 29F200 today
Here it is 29F200 file & ECU details : IAW 48P.11 HW : 16406014 HW : 934496280 SW : 16462044 SW : 9639339280 Magneti Marelli
Need to make Checksum aswell....
Thank you all
Any help ? please
Hi friend
post the original file to check the checksum, i need it for fix.
regards
Here it is original file
Sorry if i am too annoyng.....
Hi friend.
if you are realy sure is 29f200 this is your file PARCIAL, no bypass-immo only with this, but is the beginning.
sorry for my englis bro.
if no is 29f200 must be 29f400 and the immo bypass file is other.
can confirm is 29f200?
regards.
Last edited by paskizo; 27th February, 2012 at 05:30 PM. Reason: my bad english, sorry friends.
It is 29F200 for sure , so which is the next step for me ?
Program new chip ?
Or it is easyer to read eeprom from BSI fiind the Pin code and program new transponder with PP2000 ?
Anywone has another ideea ? I just need some help , i don't usualy make too many peugeot cars...
Any help is appreciate . Thank you very much
gkogkolos (3rd May, 2016)
Thank you lupu_sandu , do i need to cut a wire or just put the ecu with your immo off file and that's done ?
Unplug the Immo Box aswell ? from the ignition lock ?
Thank you and have a good night
upanico (10th April, 2018)
