Results 16 to 30 of 38
  1. #16
    Oct 2011
    hi ...
    i have this receiver in my hands and i want to restore somehow because i can not get in ip to config. it.The reason is that the man witch setup it ...dissapear ...so now i don't have the user name and the password for the ip address.
    the machine runs enigma CCcam2.0.11 by "under resistance team" or something named like this.
    probably i need some programs(?) and a full guide for someone who doesn't know much .
    at this point i'm so confused...i read a lot of posts but i didn't have any progress...
    my receiver seems to not have connection when i try to update ...my router see it in lan connections....the ip address ...the control center 2.5 seem that works but can not do anything with the tgs220_update.img.....all the channels lost...in their position appears 20 channels probably free(!)....hotbird & astra tuners are 0k........@$%$$^#$%$@@#@#%#@#@%#shit!....i want to setup it and then burn it or throw it to dogs to eat it......help me please
  2. #17
    Jun 2012
    hi....
    does this apply for upcoming Exrx?
  3. #18
    DK Veteran freck's Avatar
    Jul 2008
    Dark side of the Moon
    Explain Exrx????
    Freck
  4. #19
    May 2008
    hi
    not working for me on DM500 jade pli 3 maxvar
    comes on screen but no output
    i have this line in sh
    BQ="http://www.myweb.web.com/enigma1.tar.gz"
    is this correct
    jms
  5. #20
    Im not having success here,If someone can help me it would be great,I have commamdo 14.6 running on a DM500s the bouquets are great plus since i loaded this image i have more channels than i ever had and for the first time ever i have sky box office.I would love to sort out my itgate to do the same.
    I have followed the steps but when i press yellow button then press enigma1 to get bouquets,when the box reboots all my channels are gone and i have to do a scan to get my channels back. I know I'm doing something wrong I just dont know what. when i opened up the sh file,There was a load of text so i added my web site that holds the tar file (http//:www.myname.webs.com)I checked to see the file downloads and it does.
    I now have bouquets on the itgate but they are all blank (service has been removed) done a scan and channels are there.To get this i re-opened the .sh file to edit it and only entered the name of the website (http//:www.nymame.webs.com) still dont have sky box office its just not to be.........!
  6. #21
    Jul 2008
    Youll need to have an upto date bouquets list on your website first for the box to successfully download it.
    Its pointless otherwise.....make sure that youve got a "script" folder in var aswell.
    Plus you need to chmod the sh file to 755 for the info to come tru.
    Freck
  7. #22
    May 2008
    Quote Originally Posted by freck View Post
    Freck
    i have followed the tut but still no go
    chmod 755 the Enigma1_Bouquet_Update_userscript.sh, created script folder in /var, rebooted box, it comes on screen but the script dose not run
    i have run the sh script through dos2unix
    script still dose not run
    edit
    i have started over,
    used ultra edit to edit the sh script,
    script now runs then erases the bouquets
    any help is much appreciated.
  8. #23
    Dec 2010
    Hello all, I'm needing a little help on the old auto update i've set my website up and setup the plugin on my box but everytime i do an update my bouquet is just blank. i have the script file here if that could answer any questions.
    + BQ=http://xxxx.webs.com/enigma1.tar.gz
    + cd /tmp/
    + wget http://xxxx.webs.com/enigma1.tar.gz
    enigma1.tar-2.gz 0% | | 0 --:-- ETA
    enigma1.tar-2.gz 100% |*****************************| 52943 00:00 ETA
    Connecting to xxxx.webs.com[00.00.00.00]:00
    + chmod 755 /tmp/enigma1.tar.gz
    chmod: /tmp/enigma1.tar.gz: No such file or directory
    + tar -xzvf enigma1.tar.gz
    tar: enigma1.tar.gz: No such file or directory
    + cd /tmp/enigma1
    cd: 15: can't cd to /tmp/enigma1
    + rm -rf /var/etc/satellites.xml
    + mv /tmp/enigma1/satellites.xml /var/etc/
    mv: unable to rename `/tmp/enigma1/satellites.xml': No such file or directory
    + cd /var/tuxbox/config/enigma/
    + rm -rf userbouquet.dbe00.tv userbouquet.dbe03.tv userbouquet.dbe04.tv userbouquet.dbe05.tv userbouquet.dbe06.tv userbouquet.dbe07.tv userbouquet.dbe08.tv userbouquet.dbe09.tv userbouquet.dbe0a.tv userbouquet.dbe0b.tv userbouquet.dbe0c.tv userbouquet.dbe0d.tv userbouquet.dbe0e.tv userbouquet.dbe0f.tv userbouquet.dbe10.tv userbouquet.dbe12.tv userbouquet.dbe13.tv userbouquet.dbe15.tv userbouquet.dbe16.tv
    + rm -rf userbouquet.8ef06.radio userbouquet.94b4c.radio userbouquet.dbe00.radio userbouquet.dbe01.radio
    + rm -rf userbouquets.file.epl userbouquets.radio.epl userbouquets.tv.epl
    + rm -rf bouquets
    + rm -rf services
    + rm -rf services.locked
    + mv /tmp/enigma1/* /var/tuxbox/config/enigma/
    mv: unable to rename `/tmp/enigma1/*': No such file or directory
    + rm -rf /tmp/enigma1
    + rm -rf /tmp/enigma1.tar.gz
    + reboot
  9. #24
    Oct 2012
    I followed everything in the directions and I just can't get this plugin to work. It downloads the file and reboots but I loose all channels.
  10. #25
    Oct 2012
    Also, I'm using a openpli maxvar image and using 7zip to make the enigma1.tar.gz file. Any idea what I might be doing wrong? Or could it be that this plugin is not compatible with openpli image. By the way, I'm trying this with a dm500s receiver.
  11. #26
    Oct 2008
    Hi guys been following this tutorial seems to have everything in place how long should it take to update once you have pressed the the auto update in the yellow button menu
    cheers
    mickie
  12. #27
    Oct 2008
    sorted guys cheers
    working a treat
  13. #28
    Nov 2012
    Default help me
    how you shorted because i have same problem
  14. #29
    Nov 2012
    Default auto update
    shorted too but how to auto boot
  15. #30
    Dec 2012
    Thanks. I will try this in a moment. Would be nice to see if it can identify the satellites and download accordingly. Once I have access maybe I will play with the script.
