Guide:Auto Update Channel List/Bouquets..
Page 1 of 3 123 LastLast
Results 1 to 15 of 38
    DK Veteran freck's Avatar
    Jul 2008
    Dark side of the Moon
    Default Guide:Auto Update Channel List/Bouquets..
    Here's details of some Bouquet Update Scripts/Plugins for Enigma1 (DM500s)(TM500 Super)(Itgate) (credits to rossi2000 and jfish and u.s.)
    The Plugins download the bouquet file which you upload to a website and then extracts and install them.
    I will break this guide down into 2 parts:
    Part 1. Upload the Bouquets to website.
    Part 2. Installing the Plugin.
    Pre-Requisites
    FTP Client - to install the plugins
    DreamboxEdit - to edit channel lists
    WinRar - to rar the enigma1 or enigma2 folder
    iZarc - to convert the above .rar to .tar.gz
    Website/Hosting - to host the above file (create a free one using Webs - Make a free website, get free hosting)
    Download the latest SGTFlipFlop channel list, change your regional programs, remove any services etc... and save.
    rename the folder the files are in to enigma1
    rar this folder up
    convert with iZArc to .tar.gz
    upload the .tar.gz to web server
    test the file is downloadable, type the webaddress into browser (e.g yourwebsite.co.uk: The Leading Your Web Site Site on the Net) and check the file downloads
    For Enigma1
    DOWNLOAD PLUGIN FILES(attached)
    transfer both files into /var/tuxbox/plugins
    chmod the .sh script to 755
    open the .sh file to edit your http file location, change the url to the address where you're hosting your .tar.gz archive.
    create a folder named 'script' in the var directory
    reboot the box (eg DM500)
    when box is up and running again, press the yellow button and select Enigma1 Bouquet Update, the box will reboot after the bouquets have been updated.
    Freck
  2. The Following 2 Users Say Thank You to freck For This Useful Post:
    **OVERRIDE** (6th November, 2013), MilanFan (2nd July, 2013)
  3. #2
    Oct 2011
    This works great lets me update my Gfs for her with very little needed on her part
    could this be also adapted to download and replace a rt database file for epg how would i do that as i don't understand the script ?
    could this also be used to auto update commando 14.4??
    Thanks Again
    Oct 2011
    Ok done the RT update but any info on doing this to autoupdate commando boquets
    Jul 2008
    I dont see why not....script will work on any linux box.
    Havent seen a Commando image since the good oul cable days on the Dbox2
    Try it out and post back.....nothing to loose.
    Freck
    Oct 2011
    Freck,
    Is there anyway i can get this to run on boot? and only download when i add the update i.e it will just fail and not do anything when there is no new bouqet to download but will silently do it when there is i.e call a sh file that calls each of these sh files to keep the box working in tip top condition?
    I am very new to linux and am obviously still learning
    Stingray
    Jul 2008
    The script would have to be modded to do this and cant figure out how to config it to be able to see a the newer upload.
    Channels dont drop off very often and when they do its just the shite ones....plus the little 500 wouldnt cope with all that running in the background.
    Best to stick with what ive posted....yellow button when needed.
    Freck
    Mar 2012
    Fantastic! it worked the first time!!!!
    V.I.P. Member 2tone's Avatar
    Jun 2008
    is there a script for e2 or what changes would need done
  10. #9
    Newbie themadvictor100's Avatar
    Mar 2012
    yorkshire
    Default updated boxes
    sorry but this might sound silly but will this script work on my blade bm 7000s......
    ive only had this blade over a week and its all new to me iam trying to work my way through the forums trying to learn as i go....
  11. #10
    Jun 2008
    dont think it will as the blade is closed source receiver dose blade not have a maul download on them
  12. #11
    Jul 2008
    Quote Originally Posted by themadvictor100 View Post
    Sorry bud but not for Blades.
    Freck
  13. #12
    Jul 2008
    Quote Originally Posted by 2tone View Post
    Yeah I posted it in the DM800 pligins section aswell....slight changes.
    http://www.digital-kaos.co.uk/forums...2-only-259131/
    Freck
  14. #13
    Jun 2008
    Have try above scripts and not sure whats wrong when i put link in to web browser file downloads but when i try through box looks like script runs but nothing happens after reboot no bouquest should also say doing this with a tm500 in case there is a file name that is different
  15. #14
    Jun 2008
    Ok working now had to reboot box couple of times strange
  16. #15
    Apr 2011
    Default itgate tgc220
    hello ,
    i need help , i want to flash my itgate .
    someone can help me please. thank you
