**GUIDE** Auto Update Bouquets/Channel Lists E2 only**
Results 1 to 15 of 18
    DK Veteran freck's Avatar
    Jul 2008
    Dark side of the Moon
    Exclamation **GUIDE** Auto Update Bouquets/Channel Lists E2 only**
    Here's details of some Bouquet Update Scripts/Plugins for Enigma2 (DM500HD)(DM800HD/SE)(VU+)(credits to rossi2000 and jfish and u.s.)
    The Plugins download the bouquet file which you upload to a website and then extracts and install them.
    I will break this guide down into 2 parts:
    Part 1. Upload the Bouquets to website.
    Part 2. Installing the Plugin.
    Pre-Requisites
    FTP Client - to install the plugins
    DreamboxEdit - to edit channel lists
    WinRar - to rar the enigma1 or enigma2 folder
    iZarc - to convert the above .rar to .tar.gz
    Website/Hosting - to host the above file (create a free one using Webs - Make a free website, get free hosting)
    Download the latest SGTFlipFlop channel list, change your regional programs, remove any services etc... and save.
    rename the folder the files are in to enigma2
    rar this folder up
    convert with iZArc to .tar.gz
    upload the .tar.gz to web server
    test the file is downloadable, type the webaddress into browser (e.g yourwebsite.co.uk: The Leading Your Web Site Site on the Net) and check the file downloads
    DOWNLOAD AND INSTALL THE .IPK FILE ATTACHED
    the ipk will automatically reboot your box after installation, it will now appear in the plugins menu (green button)
    edit the .sh script in /usr/script with your file locations (i deleted the picons bit during testing)
    select the plugin to update the bouquets.
    Freck
  2. The Following 2 Users Say Thank You to freck For This Useful Post:
    patcino (26th May, 2013), surapan (3rd July, 2014)
  3. #2
    V.I.P. Member 2tone's Avatar
    Jun 2008
    tried this on my dm8000 with gp3 on it and messed up box is there some thing different about using this script with an icvs image
    DK Veteran Rodbouy's Avatar
    Quote Originally Posted by 2tone View Post
    What error did you get in the log mate?
    Jun 2008
    had to flash it again when set back up will try again and see what log says but it deleted all sats in tuner config
    Jul 2008
    Its config'd just to download 28.2E sio if youve a multi sat listing it'll overwrite it,not familiar with icvs images tbh I'd a BH man meself.
    Let me know how you get on after reflash etc.
    Freck
    Jun 2008
    Going to try a black hole image and see dose it have the same problem chance it could be my bouquest file but was made the same way as the e1 file when i tried it on a tm500 was strange it deleted my sat list in my sat set up page
    Jun 2008
    After playing with this a bit and using different images what happens is when i run the script from green button it looks like it runs but if i log in to box and check it just deletes my satellites.xml in var/tuxbox and when i check my bouquets it dose not have any of them also here is a copy of the .tar.gz file i have been using also here is a copy of the script out of usr/script
    #!/bin/sh
    set -x
    exec > /var/log/Enigma2_Bouquet_Picon_Update.log 2>&1
    #DESCRIPTION=Downloads, Installs & Reloads the latest Enigma2 Bouquets & Picons
    #Transfer script to /usr/script and chmod 755
    #A log file will be created in /var/log
    #Change the URL to point to your Bouquet tar.gz file
    BQ="http://www.xxxx/xxx/enigma2.tar.gz"
    BP="http://www.xxxx.co.uk/xxxx/picon.tar.gz"
    ## Bouquet Download, Installation + Reload ##
    cd /tmp/
    wget $BQ
    chmod 755 /tmp/enigma2.tar.gz
    tar -xzvf enigma2.tar.gz
    cd /tmp/enigma2
    rm -rf /etc/tuxbox/satellites.xml
    mv /tmp/enigma2/satellites.xml /etc/tuxbox/
    cd /etc/enigma2
    rm -rf *.tv
    rm -rf *.radio
    rm -rf blacklist
    rm -rf lamedb
    mv /tmp/enigma2/* /etc/enigma2
    rm -rf /tmp/enigma2
    rm -rf /tmp/enigma2.tar.gz
    wget -qO - http://127.0.0.1/web/servicelistreload?mode=1
    wget -qO - http://127.0.0.1/web/servicelistreload?mode=2
    ## Picon Installation ##
    cd /tmp/
    wget $BP
    chmod 755 /tmp/picon.tar.gz
    tar -xzvf picon.tar.gz
    rm -rf /media/usb/picon/
    mv /tmp/picon/ /media/usb/
    rm -rf /tmp/picon.tar.gz
    Here is mine
    #!/bin/sh
    set -x
    BQ="ftp://********:*******@**********/Bo...enigma2.tar.gz"
    #BP="http://www.xxxx.co.uk/xxxx/picon.tar.gz"
    cd /tmp/
    wget $BQ
    cd /tmp/enigma2
    cd /etc/enigma2
    rm -rf *.tv
    rm -rf *.radio
    rm -rf blacklist
    rm -rf lamedb
    rm -rf /tmp/enigma2
    #cd /tmp/
    #wget $BP
    #chmod 755 /tmp/picon.tar.gz
    #tar -xzvf picon.tar.gz
    #rm -rf /media/usb/picon/
    #mv /tmp/picon/ /media/usb/
    #rm -rf /tmp/picon.tar.gz
    Reboot
    I just # out the picon update
    I have this working on pli beta 2.1 and BH 1.6.6 and also on my mates vu Duo running BH 1.6.6
    after you do it, what does the log say ?
    If you want I will pm you my 2 .sh, one for static e2 and one for multi e2 to try from my ftp server
  10. #9
    Jun 2008
    Strange thing is i found another script on net from another forum and edited my details and it worked but with this script it wont cant work it out yet
    + BQ=ftp://www.xxxxx.co.uk/xxx/enigma2.tar.gz
    + cd /tmp/
    + wget ftp://www.xxxxxxx.co.uk/xxxx/enigma2.tar.gz
    Connecting to [url=http://www.tvchans[/url] (00.00.00.00:21)
    wget: ftp login: Login incorrect.
    + chmod 755 /tmp/enigma2.tar.gz
    chmod: /tmp/enigma2.tar.gz: No such file or directory
    + tar -xzvf enigma2.tar.gz
    tar: can't open 'enigma2.tar.gz': No such file or directory
    + cd /tmp/enigma2
    /usr/script/Enigma2_Bouquet_Picon_Update.sh: cd: line 1: can't cd to /tmp/enigma2
    + rm -rf /etc/tuxbox/satellites.xml
    + mv /tmp/enigma2/satellites.xml /etc/tuxbox/
    mv: cannot rename '/tmp/enigma2/satellites.xml': No such file or directory
    + cd /etc/enigma2
    + rm -rf bouquets.tv userbouquet.LastScanned.tv userbouquet.dbe00.tv userbouquet.dbe01.tv userbouquet.dbe02.tv userbouquet.dbe03.tv userbouquet.dbe04.tv userbouquet.dbe05.tv userbouquet.dbe06.tv userbouquet.dbe07.tv userbouquet.dbe08.tv userbouquet.dbe09.tv userbouquet.dbe0a.tv userbouquet.dbe0b.tv userbouquet.dbe0c.tv userbouquet.dbe0d.tv userbouquet.dbe0e.tv userbouquet.dbe0f.tv userbouquet.dbe10.tv userbouquet.dbe11.tv userbouquet.dbe12.tv userbouquet.dbe13.tv userbouquet.dbe14.tv userbouquet.dbe15.tv userbouquet.dbe16.tv userbouquet.favourites.tv
    + rm -rf bouquets.radio userbouquet.favourites.radio
    + rm -rf blacklist
    + rm -rf lamedb
    + mv /tmp/enigma2/* /etc/enigma2
    mv: cannot rename '/tmp/enigma2/*': No such file or directory
    + rm -rf /tmp/enigma2
    + rm -rf /tmp/enigma2.tar.gz
    + wget -qO - http://127.0.0.1/web/servicelistreload?mode=1
    <?xml version="1.0" encoding="UTF-8"?>
    <e2simplexmlresult>
    <e2state>True</e2state>
    <e2statetext>reloaded lamedb</e2statetext>
    </e2simplexmlresult>
    + wget -qO - http://127.0.0.1/web/servicelistreload?mode=2
    <e2simplexmlresult>
    <e2statetext>reloaded bouquets</e2statetext>
    + Reboot
    /usr/script/Enigma2_Bouquet_Picon_Update.sh: line 1: Reboot: not found
  11. #10
    Oct 2012
    Quote Originally Posted by freck View Post
    Pre-Requisites
    rar this folder up
    Freck
    Do it works on enigma1?
    Thanks.
  12. #11
    DK Veteran uu161's Avatar
    May 2012
    Quote Originally Posted by dutchkrus View Post
    Thanks.
    for E1
    Guide:Auto Update Channel List/Bouquets..
    if you like the post use the Like button located bottom right corner of each post
    if you wish to thanks kindly use the thanks button located bottom left corner of each post instead making a post for thanks
  13. #12
    Jun 2012
  14. #13
    Jan 2013
    what version is the best for channel updateing from ftp posted above? thx
  15. The Following User Says Thank You to lalamala For This Useful Post:
  16. #14
    Sep 2008
    this does not work 100% on all firmwares i have tried ....just says on each one .... illegal operation on line 2
    any ideas?
  17. #15
    Jul 2013
    Hi to all
    One question
    Is it possible to check if the Server where the Bouquest are is Online ore Offline?
    I mean if the Server is Down the Script deleats alle you Bouquets which are on your Dreambox right?
    I thinks it will be better if there is a IF Clause but i have no ideea how to fix that script
    Pleas post this here if any one here knows how to do this
    thanks to all o you
    greetings
    Luca1234
