Page 156 of 256 FirstFirst ... 56106146151152153154155156157158159160161166206 ... LastLast
Results 2,326 to 2,340 of 3831
  1. #2326
    Mar 2012
    the sd duplicates list has sd duplicates for movies and sport...but not for hd entertainment channels like atlantic and watch etc
    be good to have all sd duplicates....recording sd channels takes up a lot less space.
    Sent from my GT-N7100 using Tapatalk 2
  2. #2327
    Nov 2013
    mrs and and kids were getting on at me to get sky Christmas on the box, so downloaded the latest channel list, backed up my existing tp, deleted all the channels then upgraded by USB with the latest file dated 3rd December but all my channels are the same as they were before?
    what have I done wrong?
  3. #2328
    Hadron's Avatar
    Nov 2012
    E. London
    Quote Originally Posted by EvilGenius1916 View Post
    Did you delete your old TP_PROG.dbs file from your memory stick before copying the new one to it?
    If not, are you sure that you selected "copy & replace" when pasting to the memory stick?
    I am wondering if your old file is still on the memory stick.
  4. #2329
    Nov 2013
    Quote Originally Posted by Hadron View Post
    100 % copy and replace, windows 7 machine so checked the properties of the file and it was definitely the new one, only thing I'm thinking is could the backup I done have replaced the .dbs file on the stick?
    found the channel now right enough (rebranded drama/romance) but would be nice to know for the future
  5. #2330
    Hadron's Avatar
    Nov 2012
    E. London
    If you backed up your existing channel list to the same memory stick as the one you put the new one on, then your backed-up list will overwrite the new one as it has the same file name.
    Try copying the new one to the memory stick again, but this time don't back up your old one. You don't need to anyway.
  6. #2331
    Nov 2013
    Makes sense, will give that a bash
    Thanks for your help bud
  7. #2332
    Mar 2012
    can i add...something that can happen easily...if you download tp_prog.dbs last week and transfer it to your usb drive and it goes on to the box fine.....but this week you may download an update and you may not realise it will be renamed tp_prog(1).dbs and you may put this on usb and into box.....that will not work....it has to be tp_prog.dbs on usb....and if theres an old one on there it will automatically rename itself to tp_prog(1).dbs.
    my advice....empty download folder before downloading...and delete any old tp_prog.dbs before moving to usb flash drive......and confirm for yourself there is only one tp_prog.dbs on usb before transferring and that it is named correctly - tp_prog.dbs only...no digits.
  8. #2333
    Dec 2013
    Quote Originally Posted by mtv1 View Post
    what box u got ?
    did you un zip the file
    i did unzip the file and it still says file mismatch,
    i have followed the instructions from the website and now i am left just two channel lists.
  9. #2334
    Nov 2013
    All sorted mate, cheers
    All my favourites groups are still in tact and channel 5 HD is working as we'll
  10. #2335
    Hadron's Avatar
    Nov 2012
    E. London
    Quote Originally Posted by J4wdx View Post
    What is the size of the file after it is unzipped?
    It should be 1MB or 1,024kB.
    Not sure what you mean about the bit in bold?
  11. #2336
    Dec 2013
    the bit in bold means i have two channels list all satellite and sky 28a.
    the file size is 1024kb i don't understand what has happened as i cant even write the older channel list as that says file mismatch too.
  12. #2337
    Mar 2013
    Channel 5 HD and More4HD are scrambled for me on AJ's list (both on 26/11 and 3/12 - Standard List with SD Duplicates), however it was working for me on Aj Temporary Update 02/12/2013 by Sattv5
    And this has nothing to do with my sub - I can get all other $ channels just fine, apart from the two mentioned above
  13. #2338
    Nov 2008
    life ok channel not working
    Sent from my GT-I9300
  14. #2339
    same here - since Monday. not sure why. Re-scanned manually (specific to lynsatfreq -still no joy/ Any thoughts anybody. using hd800hg
  15. #2340
    Jul 2012
    is this latest update corrupt? lost a lot of channels saying no signal but looked on my other box that hasn't been updated and they're still there
