I think it's this firmware; http://www.digital-kaos.co.uk/forums...ymousx-253796/
It says both if you factory reset before upgrade, only tested on my S12.
Can somebody tell me how many channels are in the box office favourite before I download after a list with none hd sbo channels
40!! Do you have the non hd sbo on your list mate I didn't know there was 40 available
Cheers djay your list is great way better than the 1 I had, only got to watch for 5 mins then the server went down from my cs provider
Since updating I'm experiencing a lot of freezing is this down to upgrading my firmware or my provider
After updating I also experienced freezing on the encrypted channels. could view for anything between a couple of minutes to half an hour.
I believe the problem lay with the new firmware mentioned in the thread.
Tried everything I could think of. I ended up reflashing using the attached firmware. my box is a s10, this firmware works for both s10 s9. I got it from another thread on the forum here. After installing the firmware I could install the channel list, but had to rename the favorites manually. everything working well for last 2 days.
Since using AnonymouSX firmware i have had no endless trouble with it feezing and glitching on 4 boxes (S10), spent loads of time trying to find out why, even thought the boxes were faulty.
but i found that the nov firmware worked so much better without a glitch and freeze and also to point out that if you have more than 1 box on a sky lnb people say it causes the boxes not to switch to Vertical (the voltage error ). but since this Nov firmware i have got 3 boxes (S10) on same lnb working on all HD channels and not had a problem since.
I put the firmware up later if req.
How can I rename the favs as they are wrong kids is sport and vice versa and some just say fav 15
Did you reset to factory default before upgrading? My Skybox S12 is working perfectly with the firmware :/
