Page 8 of 256 FirstFirst ... 3456789101112131858108 ... LastLast
Results 106 to 120 of 3831
  1. #106
    DK Veteran DeejayAJ's Avatar
    Feb 2012
    Quote Originally Posted by SentineI View Post
    Does this have Bangladeshi channels correct(Channel S, ATN, Channel i, Channel 9)
    The one I'm currently using doesn't have it in the correct order
    They're in the list but not in the same order as sky, you can easily change that in the openbox menu yourself if needed.
  2. #107
    Jan 2012
    Sunny Morecambe
    would also like to know if this would work with the openbox x3
  3. #108
    Feb 2012
    Quote Originally Posted by gingeee85 View Post
    I would have thought so but I don't know mate, try it & let me know.
  4. #109
    Jan 2012
    Sunny Morecambe
    hopefully my x3 arrives tomorrow so i will let you know matey
  5. #110
    Jun 2012
    does this still have sound and recording issues
  6. #111
    Feb 2012
    Quote Originally Posted by coolusman View Post
    There wasn't a sound issue I just needed to update my firmware & the only recording issues were when I removed the the scrambled flags, it was fixed the same day.
  7. #112
    Jan 2012
    Sunny Morecambe
    can confirm this works perfect with the new openbox x3. such a good designed box just need epg sorting now .
    cheers deejayaj
  8. #113
    Jun 2012
    espn hd dosent seem to be working , saying scrambeled , all others are working fine except from sky 3d and espn hd. i dont know if the problem is coming from my end but please can you check on this
  9. #114
    Jun 2012
    updated on my s11 restarted and perfect, great work
  10. #115
    Jan 2011
    Ok, got the usb working again, just the channel list ( uk ) if you can help me out
    Quote Originally Posted by Manic01 View Post
    Some firmwares block the usb upgrades to avoid future damage of the receiver if wrong firmware is loaded.
    If message "upgrade file is mismatch" appears when trying to update firmware, it means usb upgrades are disabled.
    Thanks for this info, I am getting this info, any idea on how to revert back to enable???
    Could you also point me in the right direction for the uk channel list, the one I put on was the irish one.
    I take it i need return to factory settings before adding new image?
    Thanks in advance
    Tomo
  11. #116
    Jan 2011
    North West England
    Anyone got an updated list for the skybox s12? Or is March's on page 1 of this thread fine in clearing all channels?
  12. #117
    Feb 2012
    Quote Originally Posted by AfyB View Post
    I update the original files in the first post, the last update was 21/05/12.
    I'll update again sometime this week.
  13. #118
    Kumba
    Hi AJ
    I got this channels list but now needs updating especially CH 4hd which is not showing at all. If you could get a chance please look at this one and see if you can work anything out mate.
    Cheers
  14. #119
    Aug 2010
    like the list, thanks a lot, but can only seem to rename fav 1 on mine. cant get to fav 2 etc, prob me, anyone any ideas?
  15. #120
    Nov 2008
    how do we updatr transponder changes
    attheraces has changed transponder settings and i need to change it,any help appreciated
